Undercoating & Floor Pan Tar????, How to remove this crap? |
Mueller |
Mar 27 2003, 03:53 AM
I've been using brake cleaner to remove the undercoating, but it is taking forever due to how thick this cr@p is. Is there another way to remove it?
At over 2 bucks a can, this is going to be an expensive job just to remove this stuff. |
Zeke |
Mar 27 2003, 10:28 AM
Never left, but not right.... Group: Members Posts: 381 Joined: 26-January 03 From: Long Beach CA Member No.: 197 Region Association: None |
Scaping gets a lot of it, but the contours are hard to do with a lflat blade. You can modify a chisel on the grinder. I also used stropper pads and wire brushes mounted in a drill motor. I sanded as well. I really didn't get every last bit off, but it si fairly smooth under there. Good enough for paint, IMO.
Lo-Fi Version | Time is now: 28th May 2024 - 02:55 AM |
