Undercoating & Floor Pan Tar????, How to remove this crap? |
Mueller |
Mar 27 2003, 03:53 AM
I've been using brake cleaner to remove the undercoating, but it is taking forever due to how thick this cr@p is. Is there another way to remove it?
At over 2 bucks a can, this is going to be an expensive job just to remove this stuff. |
TimT |
Mar 27 2003, 05:44 PM
retired Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 |
Aircraft stripper works great, unless someone has applied an asphalt based under coating, it make a big mess with that.
I ended up using an angle grinder, with a wire wheel to get the crap off. and BTW it saves a ton of weight, I took off about 40 lbs of undercoating on my 911 here is a pic of the right front wheel well after I primed it with zinc then shot some white paint on it. |
Lo-Fi Version | Time is now: 19th May 2024 - 02:52 AM |
