Distibutor question |
tod914 |
Nov 21 2008, 03:09 PM
Need to verify a part number; 0 231 172 019 for a distibutor. I checked the
Porsche PDF and it didn't show. Is this or will this one work in a 74 2.0 ? Thanks, Tod |
Cap'n Krusty |
Nov 21 2008, 03:26 PM
Need to verify a part number; 0 231 172 019 for a distibutor. I checked the Porsche PDF and it didn't show. Is this or will this one work in a 74 2.0 ? Thanks, Tod What's the VW part number (3 groups of 3 digits, followed by 1 or 2 letters), and what 914 do you hope to use it in? The Cap'n |
TravisNeff |
Nov 21 2008, 03:29 PM
That is for a 70-73 1.7. It will work sorta. The advance curve is different from a 2.0.
I found this info on Brad Anders site. http://members.rennlist.com/pbanders/ |
tod914 |
Nov 21 2008, 03:34 PM
1.7, ty. Are the trigger points, vaccume canister, and point plate the same as a 2.0?
Cpt, was going to buy it as a spare for my 74 2.0. Didn't see any of the VW numbers on it. Only the Bosch number. Thanks fellers |
tod914 |
Nov 21 2008, 03:43 PM
Just reading through Brad's site. Such a variance on all the components.
TravisNeff |
Nov 21 2008, 03:58 PM
points plate and trigger points are interchangeable. The vacuum pot I believe have differing advance/retard values.
TravisNeff |
Nov 21 2008, 04:02 PM
Here are the distributor characteristics. I cannot locate any data on the vac cans.
Displ. Part Number Start RPM Adv@RPM Adv@RPM Adv@RPM End Displ. Part Number Start RPM Adv@RPM Adv@RPM Adv@RPM End 1.7 ? 022 905 205 A 900-1000 13-17@1500 18-21@2000 27@2900 1.7 022 905 205 A 900-1000 13-17@1500 18-21@2000 27@2900 1.7 ? 022 905 205 B 900-1000 19-22@1500 19-22@1500 27@2900 1.7 022 905 205 B 900-1000 19-22@1500 19-22@1500 27@2900 1.7 022 905 205 D 1050-1200 14-17@1500 17-20@2000 27@2900 1.7 022 905 205 D 1050-1200 14-17@1500 17-20@2000 27@2900 1.7 022 905 205 E/F 700-1050 10-15@1500 14-19@2000 22-27@3000 1.7 022 905 205 E/F 700-1050 10-15@1500 14-19@2000 22-27@3000 1.7 022 905 205 J 700-1050 10-15@1500 [not listed] 22-27@3000 1.7 022 905 205 J 700-1050 10-15@1500 [not listed] 22-27@3000 1.8 022 905 205 AA 980-1180 14.5-19@1500 23.5-26.5@2500 29-32@3400 1.8 022 905 205 AA 980-1180 14.5-19@1500 23.5-26.5@2500 29-32@3400 1.8 022 905 205 AB 980-1180 14.5-19@1500 23.5-26.5@2500 29-32@3400 1.8 022 905 205 AB 980-1180 14.5-19@1500 23.5-26.5@2500 29-32@3400 2.0 039 905 205 900-1100 6-10@1500 [not listed] 20-24@3000 2.0 039 905 205 900-1100 6-10@1500 [not listed] 20-24@3000 2.0 039 905 205 A 900-1100 4-9@1500 [not listed] 22@3000 2.0 039 905 205 A 900-1100 4-9@1500 [not listed] 22@3000 2.0 [unlabeled] 850-1150 7-12@1500 12-17@2000 20-24@2800 2.0 [unlabeled] 850-1150 7-12@1500 12-17@2000 20-24@2800 |
Lo-Fi Version | Time is now: 12th May 2024 - 04:04 PM |
