got rained on and now it wont start |
echocanyons |
Mar 27 2003, 09:50 AM
Advanced Member Group: Benefactors Posts: 2,094 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California |
OK, so I drove my 914 to work and got dumped on with rain.
When I went out to the car I tried to start it like normal and It acts like the ignition switch is broken. When I turn the key to "on" everything works but when I turn to "start" I just get this click. The storm was unexpected and most of my seals are shot so there was a significant amount of leakage in the car and in the engine compartment. I havent replaced the ignition switch yet but I wonder if this is the problem or if it could be a wiring issue. any sure ways to test? (IMG:style_emoticons/default/flag.gif) |
Jeroen |
Mar 27 2003, 10:01 AM
This may sound stoopidly simple, but since you say you only hear a "click"...
Did you check your battery? cheers, Jeroen |
echocanyons |
Mar 27 2003, 10:06 AM
Yeah I checked the voltage and it was normal I am fairly confident that its not the battery.
The click I hear is from under the dash more than from the starter and is separate from the fuel pump. I was reading the PP article on this and the relay under the seat(although bypassed the wires may have been corroded or grounding out.) Ill have to check that tonight Thanks |
Bruce Allert |
Mar 27 2003, 10:40 AM
Hellions asleep Group: Members Posts: 3,289 Joined: 19-March 03 From: Eagle Creek, Orygun Member No.: 441 Region Association: Pacific Northwest |
When I bought my 914 it didn't have a cover for the relays in the engine compartment. My mechanic stressed getting a cover. Well, wouldn't you know it,... twice before getting a cover on the relays I was dumped on and twice I had to be towed home. It was the relays ... all wet & shorting out. I dried them all w/ a hair dryer but, before I did that, all I got was clicking (IMG:style_emoticons/default/sad.gif)
bruce |
Mark Henry |
Mar 27 2003, 11:06 AM
On the battery issue clean you terminals, I've had many a good battery not work because of dirty terminals. Also unbolt the ground cable and sand to bare metal and replace. Take your jack and SAFETY STANDS. Remove the wire on the starter and scrape the connector blade clean with a knife and if you want unbolt the big wire and clean it as well. Check/unbolt/sand the ground on the tranny.
If this still doesn't work you could do the ol' screwdriver across the solenoid terminal trick to rule out the starter. This could also be used to start the car and get you home. If all this fails then you are on to the switch and stuff inside the car. Good luck (IMG:style_emoticons/default/smash.gif) |
echocanyons |
Mar 27 2003, 11:35 AM
Some good input guys I will put the info to use tonight when I get a home.
in regards to the starter test by bridging the circuits, there are three or four circuits of the starter sloenoid and I tried to bridge two of them and just got the whirr of the solenoid which terminals am I supposed to bridge? |
silver six |
Mar 27 2003, 11:43 AM
Member Group: Members Posts: 203 Joined: 3-February 03 From: San Bruno, California Member No.: 227 |
Depending on your starter you either have two big nuts and two blade connectors or you have two big nuts and a single blade connector (with multiple little wires connecting to the blades). In any case just hope to god you have two big nuts.
Connecting the two big nuts will only spin the starter but not engage the solenoid (if I remember right). You need to connect the little blade to the big nut with the power cable attached to it. I wish you and your big nuts luck. Douglas |
echocanyons |
Mar 29 2003, 09:25 AM
Turns out it was the starter.
It really just stopped working it didnt give any prior notice at all. I guess I am spending the rest of the weekend removing the seats and the carpet and drying everything. Next on my list weather seals! Thanks for all the feedback |
Aaron Cox |
Mar 29 2003, 10:22 PM
well what do you know...i had the same problem. I have a relay board cover out back. turned out to be the ignition switch (15 buckaroos from PP) also go and clean and respring alll your fuses up front.
hope this helps (IMG:style_emoticons/default/driving.gif) |
Lo-Fi Version | Time is now: 20th May 2024 - 12:09 AM |
