Cooling Fan Air Outlets, Plug or Open Running No Heat |
AvalonFal |
Nov 22 2008, 09:26 AM
Member Group: Members Posts: 483 Joined: 3-July 05 From: Southern New Jersey Coast Member No.: 4,367 Region Association: MidAtlantic Region |
I've done a search on this topic and came up with 2 different answers, so I'll start the ? over. All of my heat piping, hoses, exhangers, etc. are removed from my 2.0L (running no heat). What do I do with the 2 cooling fan air outlets.....plug them or leave open??
Paul |
Cap'n Krusty |
Nov 22 2008, 09:46 AM
If you check the archives, you'll find the answer is "Plug 'em".
The Cap'n |
AvalonFal |
Nov 22 2008, 10:58 AM
If you check the archives, you'll find the answer is "Plug 'em". The Cap'n I checked the archives. The answers are contradictory. Some say plug them. Some say DON'T plug them because of uneven head temperature issues. Some even say "partially" plug them. Even the latest post just a few months didn't end with a consensus on what to do. An unresolved question, so I ask it again. Paul |
Cap'n Krusty |
Nov 22 2008, 11:16 AM
OK. I say "plug 'em" because any air escaping there won't go over the engine to cool it. Perhaps Jake will comment. He has more current engine specific experience than I. The Cap'n
futuresoptions |
Nov 22 2008, 11:23 AM
Happy Camper Group: Members Posts: 55 Joined: 14-November 08 From: Tejas Member No.: 9,757 Region Association: None |
I plugged mine, ran my car in 100+ heat never had any issues.. I also deleted my tstat and modded the cooling flap wide open... Wouldn't figure you could get away with that in NJ though....
Gint |
Nov 22 2008, 12:12 PM
Mike Ginter Group: Admin Posts: 16,075 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
I checked the archives. The answers are contradictory. Some say plug them. Some say DON'T plug them because of uneven head temperature issues. Some even say "partially" plug them. Even the latest post just a few months didn't end with a consensus on what to do. An unresolved question, so I ask it again. I've read 'bout all of those threads. There are a lot of opinions on the subject. The outcome this time will be exactly the same. (IMG:style_emoticons/default/smile.gif) Good luck and a (IMG:style_emoticons/default/icon_bump.gif) |
Drums66 |
Nov 22 2008, 12:28 PM
914 Rudiments Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
I'm running mine the same way .......no heat
straight pipes ect. and I plug them, no cooling issues! all the mechanic's in the know say*plug them* What i'd like to get is decent ideas of what to plug them with? |
Jake Raby |
Nov 22 2008, 01:10 PM
Engine Surgeon Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
The system is designed to have a constant volume loss through the heaterboxes, as air cools them in the summer even with the heat off.
I have engines with 100K on the clock, at 175 HP that have had them open since the day the engine was fired for the first time. On our race engines we also leave them open. The results I have seen with them pluged is a CHT differential thats eklevated across all 4 cylinders. I won't make a recommendation, only tell you what I do and why I choose to do it. if the system wasn't designed with the constant volume loss I could see that plugging them would make sense. |
Lo-Fi Version | Time is now: 20th May 2024 - 07:56 AM |
