Steering Wheel Removal, Puller required? |
Slick914 |
Nov 23 2008, 10:20 AM
Member Group: Members Posts: 236 Joined: 10-June 07 From: Lorain, OH Member No.: 7,802 |
Does it require a puller or does it come off easily once unbolted?
jonferns |
Nov 23 2008, 10:44 AM
Once the retaining nut is loosened, you should be able to wiggle it off.
Slick914 |
Great, thanks!
boxstr |
Nov 23 2008, 10:56 AM
Just a quick note. Loosen the nut, but don't remove it completely. That way when you are trying to remove the wheel it won't bang you in the mouth.
Ask me why I make this suggestion. CCLINMOUTHFULLOFWHEEL |
Slick914 |
Nov 23 2008, 10:58 AM
wertygrog |
Nov 23 2008, 09:01 PM
wertygrog Group: Members Posts: 428 Joined: 12-November 05 From: Long Beach, CA Member No.: 5,114 Region Association: Southern California |
And don't forget to mark the spined shaft with respect to the steering wheel so it gets positioned right when you go to put it on....
...this from the guy who drives around with a misaligned steering wheel lol. (IMG:style_emoticons/default/smile.gif) |
VaccaRabite |
Nov 23 2008, 09:26 PM
boxstr |
Nov 23 2008, 11:07 PM
Yeah.. it only takes one time to learn that lesson.
CCLINSMASHMOUTH |
markb |
Nov 24 2008, 09:43 AM
Yeah.. it only takes one time to learn that lesson. CCLINSMASHMOUTH Some of us don't learn that fast. (IMG:style_emoticons/default/dry.gif) (IMG:style_emoticons/default/biggrin.gif) |
GeorgeRud |
Nov 24 2008, 01:14 PM
You folks don't just drive around with the wheel on the shaft without the nut on tightly? You can find a long, straight section of a seldom used road, and align the wheel on the shaft to its straightest position, then tighten the nut for the final install. I'd leave the nut on at least loosly, as I also have learned the hard way in tugging on stubborn steering wheels!
Lo-Fi Version | Time is now: 10th May 2024 - 03:26 AM |
