Winter storage questions, Yes, it's almost that time |
Cevan |
Nov 23 2008, 07:57 PM
Senior Member Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 |
I'll be storing my car in a week or so for the winter and I want to make sure I'm covering all the bases. My storage area is dry but unheated. The car will be stored for about 4 months.
Fill gas tank, use Sta-bil and run the motor to get it throughout the fuel system. Inflate tires to the max. Rodent traps on top of the tires. Cover the exhaust tip. Open the doors and trunk lips a bit. Remove battery. Should I put a bit of oil (Brad Penn of course) in each cylinder and crank the motor over? I do this for all my other gas powered items. I know Rich Towle is going to tell me to just keep driving it thru the winter but I need my garage bay so I can disassemble my '74 2.0. (IMG:style_emoticons/default/biggrin.gif) |
Nov 23 2008, 08:08 PM
Drive it you woosey.
Moth balls on the floors. Remove the flex tube to the HE and cap off the hole into the long with a spray can cover and clamp... They love to eat there way into the heating system via that tube and then live inside the long...and that smells. Also, traps and moth balls under the hood, under the windshield...another favorite place for mice to move in...both corners under the windshield seems to be a nice place to make a home. You could just drive it... I am all set up with snow tires, ready to go. Maybe if I get the short stick to get Ax at school I will take the teener and drop by some snowy day around the holidays...before or after..depends upon when I need to go get him. Rich |
championgt1 |
Nov 23 2008, 08:09 PM
Don't embarrass me Filmore! Group: Members Posts: 2,680 Joined: 3-January 07 From: Tacoma, Washington Member No.: 7,420 Region Association: Pacific Northwest |
Looks like a good list to me. I am not sure about the oil in the cylinders. Is that necessary?
Pat Garvey |
Nov 23 2008, 08:45 PM
Spider traps! They work.
I get mine from the the dealer that services our store. Little white "homes", where they go in to warm up - don't come out alive. Jeez, I hate spiders! Pat |
sixnotfour |
Nov 23 2008, 09:17 PM
914 Wizard Group: Members Posts: 10,430 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
QUOTE Also, traps and moth balls under the hood, under the windshield...another favorite place for mice to move in...both corners under the windshield seems to be a nice place to make a home. The mice enter through the hole below the fuel tank, they jump up on gravel panel and come up through the fuel tank access hole. |
justme |
Nov 23 2008, 09:20 PM
Member Group: Members Posts: 187 Joined: 1-January 07 From: southampton ma atlantic northeast Member No.: 7,413 Region Association: North East States |
As far as rodents go those large car "bags" work well for a budy of mine that put's his cars in his barn over in Hadley.
Peanutbutter on the old snap traps works well on my country mice. But my cars are in the old attached garage, carpet & heat. My wife actually had the nut's to ask me if I wanted to put the Porsche's in storage so she could park her car in the garage (IMG:style_emoticons/default/av-943.gif) |
Gint |
Nov 24 2008, 09:56 AM
Mike Ginter Group: Admin Posts: 16,071 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Just curious...
Even in a state like Mass, aren't the roads dry enough once every couple of weeks or so that you could drive a 914? |
Nov 24 2008, 09:58 AM
rjames |
Nov 24 2008, 11:33 AM
I'm made of metal Group: Members Posts: 3,928 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
QUOTE Fill gas tank, use Sta-bil and run the motor to get it throughout the fuel system. How long does a car have to sit before one should use some sort of gas stabilizer? |
Mark Henry |
Nov 24 2008, 12:21 PM
Gas starts to go bad the second you fill a tank, in about 4-6 weeks or less you'll start to smell it.
All of the above plus: For mice I use dryer sheets, smell better than mothballs too. (be warned that if you use dryer sheets in the engine bay the fan will suck them in.) Instead of oil I fog the engine with engine storage spray, I use quicksilver, mercury outboard storage spray. |
Pat Garvey |
Nov 24 2008, 08:08 PM
Just curious... Even in a state like Mass, aren't the roads dry enough once every couple of weeks or so that you could drive a 914? Yes, but they are ALWAYS covered in salt... I drive and I use the car wash regularly Rich Car wash! Regularly! OMG! You allow water to touch a 914? Sorry, I couldn't help myself. '72 914 - original owner - no rain/water since 1975. Dry wash only. Yes, I am certifiable! But fuzzy. Pat |
ejm |
Nov 24 2008, 08:27 PM
I can see the light at the end of the tunnel Group: Members Posts: 2,691 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
Just curious... Even in a state like Mass, aren't the roads dry enough once every couple of weeks or so that you could drive a 914? Yup Attached image(s) |
justme |
Nov 24 2008, 09:56 PM
ejm |
Nov 25 2008, 05:24 AM
Mount Lizzie at the Quabbin
Nov 25 2008, 08:26 AM
Looked a bit short for the loaf.
Rich |
rick 918-S |
Nov 25 2008, 08:37 AM
Hey nice rack! -Celette Group: Members Posts: 20,452 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Just curious... Even in a state like Mass, aren't the roads dry enough once every couple of weeks or so that you could drive a 914? Yup Dang! that looks like a section of two lane on the way to Ely MN. Mine is in storage. Stay-Bil. I think I need to cap the heater tubes yet. But I may take it out for a short run today. I still have the insurance on it. |
justme |
Nov 25 2008, 06:22 PM
Looked a bit short for the loaf. Rich Leave it to Rich to compare the size of his loaf (IMG:style_emoticons/default/stromberg.gif) |
Nov 25 2008, 06:56 PM
Looked a bit short for the loaf. Rich Leave it to Rich to compare the size of his loaf (IMG:style_emoticons/default/stromberg.gif) Size matters baby.... At least I wont be driving a pink car.....geez Rich |
tod914 |
Nov 25 2008, 07:38 PM
Maybe put a vapor barrier on the garage floor to minimize the condensation
on the bottom of the car. |
Ericv1 |
Nov 25 2008, 07:57 PM
Member Group: Members Posts: 259 Joined: 30-December 07 From: Cincinnati, Ohio Member No.: 8,518 Region Association: Upper MidWest |
Maybe put a vapor barrier on the garage floor to minimize the condensation on the bottom of the car. Do you guys get condensation in the winter? It's pretty cold and dry in Ohio. I usually don't see condensation until spring. Pat.. What's the drywash that your referring to? Thanks, Eric |
Lo-Fi Version | Time is now: 12th May 2024 - 01:20 AM |
