Changing exchangers from '75 1.8 to early 2.0, Do I need different J tubes? |
johnnie5 |
Nov 27 2008, 10:31 AM
914 lover Group: Members Posts: 375 Joined: 14-October 08 From: San Diego, CA Member No.: 9,644 Region Association: Southern California |
Hi all,
I am getting ready to put one of Marks 2056's in (IMG:style_emoticons/default/piratenanner.gif) So I have also purchased 2.0 ssi's, a 2.0 bracket, and a 2.0 Bursch. I have the flappers from my old exchangers. I think I need different J tubes? Any other different parts? Even though I have dropped the exhaust and headers/exchangers, I haven't swapped/taken out the stock 1.8 yet, so not sure.... |
shelby/914 |
Nov 27 2008, 03:31 PM
Senior Member Group: Members Posts: 804 Joined: 24-August 05 From: Foxfield, Co Member No.: 4,655 Region Association: Rocky Mountains |
I'm about to do the same thing. It's been a long time since I took the heat off my '76 and backed dated the heat exchangers but I believe most if not all of the heat tubes are different. Anyway I sourced everything from a '74 parts car and had them powdercoated and bought new flapper boxes, just haven't installed any of it yet. Both Pelican and AA have some good charts on line showing all of the parts needed and how they go together. good luck
Nov 27 2008, 05:54 PM
They are different. Everything but the flapper valves and hoses from there to the body are different. You'll need to raid an early car for parts...
--DD |
Cevan |
Nov 27 2008, 05:56 PM
Senior Member Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 |
I used the branch pipes from my '75 1.8 when I converted my exhaust to the SSI 2.0 HEs. I would assume the j-tubes that go up thru the engine tin would also work.
tod914 |
Nov 28 2008, 03:00 PM
The J's are different, as are the other parts. If either of you guys need some of the parts, I have extra from when I did my 75. I know the heat shields I had power coated in a satin black. Let me know if I can be of help. The new production dansk flapper boxes are angled different the older ones. If you decide to go with new for them, you might find the cables are too short. I ended up using a piece of heavy
gauge wire to extend it. |
Lo-Fi Version | Time is now: 14th May 2024 - 04:44 PM |
