Re-assembly Lubricants and other POL products, Anyone have a list of what to use where? |
stephenaki |
Nov 28 2008, 04:39 AM
Can I get this one dad?? Group: Members Posts: 1,183 Joined: 11-August 07 From: Palmetto, FL Member No.: 7,987 Region Association: None |
OK, I have been doing some searching but can't quite find a definitive answer anywhere. Here is what I have from Jake's forum, PP and a couple of other places.
Crankcase sealant - Curil K2 Bearings, cam, connecting rod assembly - Lithium engine assembly grease or, 20WT motor oil mixed with a little STP oil treatment Oil pump - Loctite 565 Stud threads (into case, use with nuts as well?) Loctite 262. All other thread and nuts?? I have to run to Trost here in Stuttgart to get the lubes, loctite, etc. and would appreciate input on what all I need to get. I am hoping that I can start re-assembly next weekend as I still don't have the new bearings in yet and I am waiting for the push tubes. |
VaccaRabite |
Nov 28 2008, 09:47 AM
OK, I have been doing some searching but can't quite find a definitive answer anywhere. Here is what I have from Jake's forum, PP and a couple of other places. Crankcase sealant - Curil K2 Bearings, cam, connecting rod assembly - Lithium engine assembly grease or, 20WT motor oil mixed with a little STP oil treatment Oil pump - Loctite 565 Stud threads (into case, use with nuts as well?) Loctite 262. All other thread and nuts?? I have to run to Trost here in Stuttgart to get the lubes, loctite, etc. and would appreciate input on what all I need to get. I am hoping that I can start re-assembly next weekend as I still don't have the new bearings in yet and I am waiting for the push tubes. Casesealant: Loctite 474 bearings: Brad penn oil (a lot, same as I use when running the car) Cam/pistons: assembly lube I would not put locktite on studs. Unless you never want to be able to pull them again. I put hi-temp antiseize on most of my nuts. and a THIN coat of rvt on the paper oil pump seals. Zach |
Lo-Fi Version | Time is now: 13th May 2024 - 09:04 PM |
