Interior backpad light, Variances |
Pat Garvey |
Nov 30 2008, 08:49 PM
Has anyone every documented the variations of 914 backpad lights? I mean the factory lights, not the 9.95 knockoffs. Did any "real" ones not have "chrome" outer ring? Can the "chrome" be refurbished?
I know of two - any more? Yes, I know, pics would help. My camera battery is dead tonight. If no one else posts pics I will tomorrow. Pat |
jonferns |
Nov 30 2008, 09:04 PM
Here's one of my interior light (pics courtesy of Tom Bliznik)
I also have another one that im not 100% sure of the name, but it may be a Sigla. It also has the chrome trim and white button but is definetly not Hella. I will get pics of it soon. |
914Sixer |
Dec 1 2008, 04:04 PM
914 Guru Group: Members Posts: 8,873 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
i have one with the chrome trim also, but I can not find right now for a picture.
Pat Garvey |
Dec 1 2008, 07:41 PM
Here's one of my interior light (pics courtesy of Tom Bliznik) I also have another one that im not 100% sure of the name, but it may be a Sigla. It also has the chrome trim and white button but is definetly not Hella. I will get pics of it soon. Jon, I have one just like yours, as well as the one that is original to my 914 - and somewhat different. Forgot to charge my camera battery, so it will be tomorrow before I can post. Yours has the same problem as mine. The "chrome" has degraded somewhat. So, is there some compound/paint/whatever that can be used to restore/reburbish the "plating"? Pat |
jonferns |
Dec 1 2008, 07:45 PM
I gave this some thought and came up with the idea of buying a can of "chrome" spray paint, not silver or metallic, but actual chrome (IIRC, rustoleum makes it as well as a few other brands) Then spraying a small amount into a container and using a very fine paint brush to apply it to the inside edge of the light, to fill in any voids in the chrome. I'll probably try doing this to the broken light that I have and see how it turns out.
Pat, how does your original light differ? |
Pat Garvey |
Dec 2 2008, 08:51 PM
I gave this some thought and came up with the idea of buying a can of "chrome" spray paint, not silver or metallic, but actual chrome (IIRC, rustoleum makes it as well as a few other brands) Then spraying a small amount into a container and using a very fine paint brush to apply it to the inside edge of the light, to fill in any voids in the chrome. I'll probably try doing this to the broken light that I have and see how it turns out. Pat, how does your original light differ? Jon, My original is the same, but I had a bud many years ago with a '75 that had a simplified light, yet chrome trim. See pics. Mine (cracked) is on the top. An eBay Mexican special is on the bottom - no chrome, but the connectors for my bud's '75 were similar. Attached thumbnail(s) |
rgalla9146 |
Feb 4 2009, 09:18 AM
Has anyone every documented the variations of 914 backpad lights? I mean the factory lights, not the 9.95 knockoffs. Did any "real" ones not have "chrome" outer ring? Can the "chrome" be refurbished? I know of two - any more? Yes, I know, pics would help. My camera battery is dead tonight. If no one else posts pics I will tomorrow. Pat |
rgalla9146 |
Feb 4 2009, 09:24 AM
Has anyone every documented the variations of 914 backpad lights? I mean the factory lights, not the 9.95 knockoffs. Did any "real" ones not have "chrome" outer ring? Can the "chrome" be refurbished? I know of two - any more? Yes, I know, pics would help. My camera battery is dead tonight. If no one else posts pics I will tomorrow. Pat I'll try to send pics of two odd lights that I have. Both original |
rgalla9146 |
Feb 4 2009, 09:29 AM
smg914 |
Feb 4 2009, 09:57 AM
Sahara Beige Steve Group: Members Posts: 1,962 Joined: 22-February 04 From: Tampa, FL Member No.: 1,695 Region Association: None |
I gave this some thought and came up with the idea of buying a can of "chrome" spray paint, not silver or metallic, but actual chrome (IIRC, rustoleum makes it as well as a few other brands) Then spraying a small amount into a container and using a very fine paint brush to apply it to the inside edge of the light, to fill in any voids in the chrome. I'll probably try doing this to the broken light that I have and see how it turns out. Pat, how does your original light differ? I tried the exact same process a few years ago and it looked terrible. Even though I used "chrome" spray paint, it ended up looking more gray then chrome. |
tod914 |
Feb 4 2009, 11:52 AM
What about paint made for plastics.. like testors model paint (enamel). I would think they offer a chrome in a spray can.
Pat Garvey |
Feb 5 2009, 07:19 PM
What about paint made for plastics.. like testors model paint (enamel). I would think they offer a chrome in a spray can. No, I don't think so. May work on the cheapy aftermarket lenses, where ther is nothing, but doubtless on the orig's. Thought about trying to completely remove the original "silver", but it's in a "corrugated" (for lack of another term, finish & would be impossible to remove in it's entirety (or nearly so). I'm a model railroader & know how to use an airbrush, but that's not the answer unless you can remove the original coating, which seems to be impossible & not compliant with contemporary paints. So, I'll just maintain my uncracked lens, with a couple of boogers, and the patina of age. Not the end of theworld. Pat |
tod914 |
Feb 5 2009, 08:06 PM
Alittle pig snot goes along way. I have a can of duplicolor chrome hanging around. I'll post the results when I get a chance to see how it looks.
Pat Garvey |
Feb 8 2009, 07:38 PM
Alittle pig snot goes along way. I have a can of duplicolor chrome hanging around. I'll post the results when I get a chance to see how it looks. Wait till it gets a little warmer, my friend - like April. Pig snot does not adhere well in cold climes. It sticks, but melts later. I know pig snot. |
mrgreenjeans |
Feb 22 2009, 07:55 PM
mrgreenjeans Group: Members Posts: 213 Joined: 9-February 07 From: N.Dak. Member No.: 7,520 Region Association: Northstar Region |
Here's one of my interior light (pics courtesy of Tom Bliznik) I also have another one that im not 100% sure of the name, but it may be a Sigla. It also has the chrome trim and white button but is definetly not Hella. I will get pics of it soon. For reference purpose, this light appears as the original light in my 74 - 2.0. Also for reference: The car is a VERY early build 74, with alot of 73 specific items attached, as it came from Porsche /VW. Its number is 00089 and was fabricated at Karmann in August of 1973. The light is uncracked, and shows no evidence of dirt or delamination of the silvering. One question : Would it work to send one of these bruised, dirty, and disfigured lites to some of these guys that do vaccum chroming as on the mid sixties American cars with silvered armrests, dashes, and the like ? I believe there is a company in Mpls, Mn. that does this, and advertises in enthusiast mags like Mopar Muscle, or Mustang . |
Pat Garvey |
Mar 15 2009, 07:21 PM
Here's one of my interior light (pics courtesy of Tom Bliznik) I also have another one that im not 100% sure of the name, but it may be a Sigla. It also has the chrome trim and white button but is definetly not Hella. I will get pics of it soon. For reference purpose, this light appears as the original light in my 74 - 2.0. Also for reference: The car is a VERY early build 74, with alot of 73 specific items attached, as it came from Porsche /VW. Its number is 00089 and was fabricated at Karmann in August of 1973. The light is uncracked, and shows no evidence of dirt or delamination of the silvering. One question : Would it work to send one of these bruised, dirty, and disfigured lites to some of these guys that do vaccum chroming as on the mid sixties American cars with silvered armrests, dashes, and the like ? I believe there is a company in Mpls, Mn. that does this, and advertises in enthusiast mags like Mopar Muscle, or Mustang . You pose an an interesting question! There is also a company in Canada (name eludes me)that did a set of foglight grills that I got from a member of this group. Superior quality, though they mention care for use in harsh climates. Could be an answer, but I do know that it's expensive. Pat |
MDG |
Mar 16 2009, 07:38 AM
Wolf in wolf's clothing. Group: Members Posts: 8,652 Joined: 3-February 09 From: Toronto Member No.: 10,018 Region Association: None |
Never used them but this place out in B.C. does it; C.V. Vacuum Platers Inc.
I'm pretty sure they have a website if you want to check them out. m. |
Pat Garvey |
Mar 16 2009, 06:44 PM
Never used them but this place out in B.C. does it; C.V. Vacuum Platers Inc. I'm pretty sure they have a website if you want to check them out. m. That's the place! They did some foglight grills for a member of this forum & they are totally, totally awesome. I'm fortunate to have 2 of them. The work is premier. Wonder if it can transfer to backpad lights. Also wonder if it is cost efficient. Those foglight grills were really expensive. Pat |
MDG |
Mar 16 2009, 07:08 PM
their site has a partial price list; not the best website by far but enough photos to show you what they do. A few pics of Detroit car interior bits that would leave me believing any of the small chromed plastic parts for our cars would be no problem.
The parts would be so lightweight I'm sure postal service would be fine and keep shipping costs down. Of course, putting an NLA part in the hands of either USPS or our Canada Post could be nightmare inducing. Might be better to cough up for a reputable courier. m. |
Pat Garvey |
Mar 16 2009, 07:22 PM
their site has a partial price list; not the best website by far but enough photos to show you what they do. A few pics of Detroit car interior bits that would leave me believing any of the small chromed plastic parts for our cars would be no problem. The parts would be so lightweight I'm sure postal service would be fine and keep shipping costs down. Of course, putting an NLA part in the hands of either USPS or our Canada Post could be nightmare inducing. Might be better to cough up for a reputable courier. m. Yeah, but let's think about the onesies/twosies that some of us have, that need to have the old plating stripped first. How do we get that done? I suspect that, unless we have a dozen or so that need to be redone, they won't touch us (economies of scale). Not that I'm not ready to commit, but look at the two questions. Pat |
Lo-Fi Version | Time is now: 3rd May 2024 - 05:32 PM |
