Weber DFEV ?, Keep or dump???? |
rdr |
Dec 1 2008, 03:53 PM
Newbie Group: Members Posts: 47 Joined: 13-November 08 From: Baltimore, Md Member No.: 9,749 Region Association: North East States |
Hi all,
My newly acquired 74-1.8 has the single Weber DFEV progressive carb installed. I don't yet know how it runs although reading on this carb indicates it is a bit of a dog. Fuel pooling etc. Is anyone running this setup? Theis will eventually be a weekend driver with trips to work, etc. Not really an AX car, but I would like a bit of snappy response when I get into it. Any thoughts? Leav it? Look for a 40 set? Thanks to all! (IMG:style_emoticons/default/piratenanner.gif) |
ONTHEGRIND |
Dec 1 2008, 03:55 PM
Member Group: Members Posts: 286 Joined: 10-November 08 From: California Member No.: 9,738 Region Association: None |
Hi all, My newly acquired 74-1.8 has the single Weber DFEV progressive carb installed. I don't yet know how it runs although reading on this carb indicates it is a bit of a dog. Fuel pooling etc. Is anyone running this setup? Theis will eventually be a weekend driver with trips to work, etc. Not really an AX car, but I would like a bit of snappy response when I get into it. Any thoughts? Leav it? Look for a 40 set? Thanks to all! (IMG:style_emoticons/default/piratenanner.gif) It will be good enough to get the engine started rite..? I'd say start there then ungrade.. |
So.Cal.914 |
Dec 1 2008, 04:06 PM
Sorry but yes its a POS. It will run with it but I sudjest you look else where. 40 should be fine for a 1.8, just jet them for your needs.
Spoke |
Dec 1 2008, 04:22 PM
I changed from center carb to IDF40s. Huge difference in response of the engine and the sound. Love those 4 carbs singing away. Drive your car until you find a nice set of IDF40s then upgrade. BTW, all new members must post pics of their cars. Otherwise you will be hit with a: (IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif) |
Mark Henry |
Dec 1 2008, 04:26 PM
You must test the float on those....find a large body of water, toss it in and if it floats use it.
rdr |
Dec 1 2008, 05:12 PM
hehehe... ok, here is the car. Needs work. $500 special for a74-1.8 ltr.
Bringing it home..... (IMG:http://www.britishautosports.com/914/home1.jpg) The single carb ..... (IMG:http://www.britishautosports.com/914/norelay.jpg) Gutted within the first 10 hours of bringing it home ... (IMG:http://www.britishautosports.com/914/11_29_5.jpg) Tubs of spare parts ... (IMG:http://www.britishautosports.com/914/tub1.jpg) (IMG:http://www.britishautosports.com/914/tub2.jpg) Spare brake calipers .... what a deal! (IMG:http://www.britishautosports.com/914/11_29_6.jpg) Here is a Lotus that I finished. That's why I bought the 914. Needed something to do. (IMG:http://www.britishautosports.com/914/lotus.jpg) |
VaccaRabite |
Dec 1 2008, 07:13 PM
Here is a Lotus that I finished. That's why I bought the 914. Needed something to do. (IMG:http://www.britishautosports.com/914/lotus.jpg) When you give the singe progressive carb the float test, tie those Fram oil filters on too. You do all that nice work and then add a Fram?! (IMG:style_emoticons/default/slap.gif) (IMG:style_emoticons/default/stirthepot.gif) Zach |
rdr |
Dec 1 2008, 07:42 PM
ha! Ok, I agree, (IMG:style_emoticons/default/agree.gif) but remember, there are 2 of them so that the filtering ability is x2 which probably equates to 1 Purolator One. And, the car had only about 400 miles since the rebuild. I did tell the new owner (sold it to buy the 914 (IMG:style_emoticons/default/aktion035.gif) ) to use better filters.
Buy, hey, thanks ffor noticing! (IMG:style_emoticons/default/santa_smiley.gif) |
GeorgeRud |
Dec 1 2008, 10:25 PM
Nice job on the Europa. I remember the days when I could fit in one, many many years ago.
I always thought the Lotuses (Loti?) were also great cars for an enthusiast that was willing to put up with their issues. A friend spent several years restoring a Lotus 6 that I had to pass on (due to having 4 Porsches in various stages of disassembly in the garage), and I regret not picking it up to this day. Also, how could someone not like cars that were driven by Emma Peel (or the Prisoner for that matter)? |
VaccaRabite |
Dec 2 2008, 10:30 AM
ha! Ok, I agree, (IMG:style_emoticons/default/agree.gif) but remember, there are 2 of them so that the filtering ability is x2 which probably equates to 1 Purolator One. And, the car had only about 400 miles since the rebuild. I did tell the new owner (sold it to buy the 914 (IMG:style_emoticons/default/aktion035.gif) ) to use better filters. Buy, hey, thanks ffor noticing! (IMG:style_emoticons/default/santa_smiley.gif) I just noticed that you are another local in Baltimore. Where abouts? Change your region to Mid Atlantic instead of N.E. states. We are starting to get a pretty active local group around here. :-) Zach |
Lo-Fi Version | Time is now: 13th May 2024 - 04:08 AM |
