Removing Bumpers |
Removing Bumpers |
RonnieJ |
Dec 2 2008, 11:58 AM
RonnieJ Group: Members Posts: 230 Joined: 16-June 03 From: Sterling Heights, Michigan Member No.: 829 Region Association: Upper MidWest |
How difficult is it to remove the rubber bumpers froma 75 914? I am going to send it in for media blasting prior to paint and am removing as much as possible myself prior to getting it stripped. Thanks
Kirmizi |
Dec 2 2008, 12:18 PM
Senior Member Group: Members Posts: 836 Joined: 12-February 06 From: Wyoming, US Member No.: 5,568 Region Association: None |
Not difficult at all.
Two bolts, accessed from the bottom of both bumpers, allow them to be removed from the shocks. Remember the wiring for the license plate lights when removing the rear. Mike |
Bruce Hinds |
Dec 2 2008, 12:19 PM
V-8 madness Group: Members Posts: 733 Joined: 27-December 06 From: Port Orchard, WA Member No.: 7,391 Region Association: Pacific Northwest |
Easy!
Just two big bolts front and two in the rear. 17 or 19mm, can't remember. Look up from underneath and you'll see the holes. B |
RonnieJ |
Dec 2 2008, 12:53 PM
Gentelmen, Thank you (IMG:style_emoticons/default/bye1.gif)
ConeDodger |
Dec 2 2008, 01:11 PM
Apex killer! Group: Members Posts: 23,580 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Not that easy but almost...
The sides and maybe the top of your bumper are "hooked" to the body via rubber hooks on the inside. The body itself has metal pieces attached that the rubber grabs on to. You have to basically disingage these rubber hooks from the metal. Not too hard to get off but putting it back on is a major league bitch. That rubber is old enough so getting it stretched over those metal peices is a real bear! Good luck... |
jim_hoyland |
Dec 2 2008, 04:07 PM
Get that VIN ? Group: Members Posts: 9,277 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Prior to reinstallation, loosen the three bolts holding the bumper shock to the body. This will make it easier to get the two bumper bolts started when you reattach the bumper.
Lo-Fi Version | Time is now: 9th May 2024 - 09:58 AM |
