RonnieJ
Dec 2 2008, 11:58 AM
How difficult is it to remove the rubber bumpers froma 75 914? I am going to send it in for media blasting prior to paint and am removing as much as possible myself prior to getting it stripped. Thanks
Kirmizi
Dec 2 2008, 12:18 PM
Not difficult at all.
Two bolts, accessed from the bottom of both bumpers, allow them to be removed from the shocks. Remember the wiring for the license plate lights when removing the rear.
Mike
Bruce Hinds
Dec 2 2008, 12:19 PM
Easy!
Just two big bolts front and two in the rear. 17 or 19mm, can't remember. Look up from underneath and you'll see the holes.
B
RonnieJ
Dec 2 2008, 12:53 PM
Gentelmen, Thank you
ConeDodger
Dec 2 2008, 01:11 PM
Not that easy but almost...
The sides and maybe the top of your bumper are "hooked" to the body via rubber hooks on the inside. The body itself has metal pieces attached that the rubber grabs on to. You have to basically disingage these rubber hooks from the metal. Not too hard to get off but putting it back on is a major league bitch. That rubber is old enough so getting it stretched over those metal peices is a real bear!
Good luck...
jim_hoyland
Dec 2 2008, 04:07 PM
Prior to reinstallation, loosen the three bolts holding the bumper shock to the body. This will make it easier to get the two bumper bolts started when you reattach the bumper.
