Speedo help on flipped 915? |
Nana's_914 |
Dec 2 2008, 01:22 PM
Member Group: Members Posts: 98 Joined: 27-October 06 From: San Diego, CA Member No.: 7,100 Region Association: Southern California |
What needs to be done to make the 911 speedo function with a 915/61 that had the diff flipped? The pickup needs to be on the other side, right? Where should it go and how?
Dec 2 2008, 01:37 PM
What needs to be done to make the 911 speedo function with a 915/61 that had the diff flipped? The pickup needs to be on the other side, right? Where should it go and how? I am guessing here...but it may give you a good place to start looking. If its an electronic speedo its probably using a hall effect sender. With these senders the magnet is in the speedo and could just be a tab on the ring pinion shaft or drive shaft at the back of the case...not sure. Take a look at the sender and see what metal tab passes through the sender body to create the magnetic field... Rich |
ChrisFoley |
Dec 2 2008, 04:50 PM
I am Tangerine Racing Group: Members Posts: 7,925 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
You can machine/epoxy a pocket in the side cover for the stock pickup/sending unit.
I have pictures somewhere that I'll try to find for you. Or you could mount magnets onto a cv joint and make a bracket to support the pickup nearby. |
ejm |
Dec 2 2008, 05:42 PM
I can see the light at the end of the tunnel Group: Members Posts: 2,691 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
The magnets are carried in an aluminum plate that is pinned from rotating and held down by the bearing. Be sure to check or renew the epoxy that holds the magnets in place. This is how you move the sender pocket to the other side.
Lo-Fi Version | Time is now: 13th May 2024 - 12:53 PM |
