QUOTE(Nana's_914 @ Dec 2 2008, 02:22 PM)
What needs to be done to make the 911 speedo function with a 915/61 that had the diff flipped? The pickup needs to be on the other side, right? Where should it go and how?
I am guessing here...but it may give you a good place to start looking.
If its an electronic speedo its probably using a hall effect sender.
With these senders the magnet is in the speedo and could just be a tab on the ring pinion shaft or drive shaft at the back of the case...not sure.
Take a look at the sender and see what metal tab passes through the sender body to create the magnetic field...
Rich
