firewall (internal) insulation |
zeezee |
Dec 2 2008, 03:12 PM
Member Group: Members Posts: 115 Joined: 16-October 08 From: san ramon, ca Member No.: 9,651 Region Association: Northern California |
Is the tarish/rubber padding behind the backpad and glued to the firewall worth keeping? I'm assuming it's mainly for sound insulation.
Would I be better off replacing it with Dynamat type insulation? I've had to scrape the tar off the floors under the seats - and will be replacing that with Dynamat type insulation ... why not do more? Doors too? Actually I'll be using RAAMmat BXT - if there are any opinions out there... |
So.Cal.914 |
Dec 2 2008, 03:23 PM
I have seen sound mat used in the doors, on the firewall, and the floor. But I will pass this along sense you live where it rains. Our cars leak, some of them Really leak. The reason the floors rust out on a regular basis is because of these leaks. I have heard more than once not to put anything on the floor that will absorb water and hold it there. If you will not drive it in the rain then no problem. And Welcome.
StratPlayer |
Dec 2 2008, 04:11 PM
StratPlayer Group: Members Posts: 3,278 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
I used aviation soundproofing, it comes in sheets various thickness. It works great, light weight and very efficient. I bought a sheet of this stuff on ebay a long time ago, heres a site with basically the same product. It didn't interfere with the back pad install what so ever.
http://www.aircraftspruce.com/menus/ap/soundproof.html |
VaccaRabite |
Dec 2 2008, 05:15 PM
I went with Raamat with mine. The layer of foil helps with sound deadening. I am not going to do the engine side of the firewall unless the noise is really bad, and I think I'd do a second layer on the cabin side before I put a layer on the engine side. in the event of a fire, it would also be less of something that might burn.
Zach |
southernmost914 |
Dec 2 2008, 06:39 PM
KEY WEST/HAVANA Tunnel Authority Group: Members Posts: 338 Joined: 16-October 07 From: Key West/ St. Augie, Fl USA Member No.: 8,234 Region Association: South East States |
IMHO. Use the original mat and seal the edges with 3m 5200, top and sides, but not the bottom. It is a good sound deadening product, and original.
Steve |
carr914 |
Dec 3 2008, 07:39 AM
Racer from Birth Group: Members Posts: 118,516 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
I used two layers of RAAMmat, a layer of their foam and then a layer of Perlon to look like the 914-6 GTs, no problems, pretty easy install.
T.C. zeezee, (IMG:style_emoticons/default/welcome.png) |
Bartlett 914 |
Dec 3 2008, 08:22 AM
Advanced Member Group: Members Posts: 2,215 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
IMHO. Use the original mat and seal the edges with 3m 5200, top and sides, but not the bottom. It is a good sound deadening product, and original. Steve I have 2 original mats and was thinking about using them. I like the idea of not gluing the lower edge. Should moisture collect behind the mat, it has a way out. Sound like good advice. |
burton73 |
Dec 3 2008, 07:37 PM
burton73 Group: Members Posts: 3,515 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
The stuff on the floor is totally different than the stuff on the firewall. When I put the new product on the floor it was a tar like material and the back pad was a fiber of some kind I can see where the firewall material could soak up water from a leak in the rear window.
On my 6 , I went with factory Wurth stuff. Description Of Product: The original German made material in heatable-beatable sheets. When installed, it duplicates the original sound deadening for the perfect concours look. One package completes one side. wurth FLOOR PAN TAR INSULATING KIT; 914 1970-76 I got it from AA. Bob (IMG:style_emoticons/default/welcome.png) |
Lo-Fi Version | Time is now: 11th May 2024 - 12:07 AM |
