oil cooler |
oil cooler |
kylefisk |
Dec 3 2008, 07:20 AM
Newbie Group: Members Posts: 1 Joined: 3-December 08 From: Florida Member No.: 9,810 Region Association: None |
I'm trying to set up an oil cooler on a 77 2.7 going in my 914. where is the best place to find fittings, thermastat, tanks, coolers, etc. i figure barbed fittings should work, at least until I can afford to sink money into AN fittings and lines, but I'm having a hard time finding parts that will work and be cheap. how much of a cooler do I need. I have a B&M 70266 in the shop somewhere with a 2100 cfm fan that will fit it. my biggest problem is finding a fitting that goes from the engine (20mm x 1.5) to a 3/8 barb. any ideas? thanks
carr914 |
Dec 3 2008, 07:31 AM
Racer from Birth Group: Members Posts: 118,490 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
(IMG:style_emoticons/default/welcome.png) Where in Florida are you? If you aren't going to track the car, I would run it with the factory cooler and wait til you can afford the correct lines and fittings to do an auxillery cooler.
T.C. |
jc914 |
Dec 3 2008, 11:35 AM
Member Group: Members Posts: 289 Joined: 15-September 08 From: Miami, Florida Member No.: 9,548 Region Association: South East States |
wertygrog |
Dec 3 2008, 03:05 PM
wertygrog Group: Members Posts: 428 Joined: 12-November 05 From: Long Beach, CA Member No.: 5,114 Region Association: Southern California |
McMark |
Dec 3 2008, 03:33 PM
http://www.pegasusautoracing.com has a lot of good parts. I've used their coolers and like them a lot. Make sure that the external cooler is rubber mounted to the chassis. Minor chassis flex can crack a solid mounted cooler.
This is on a Bug, but you can see the rubber strap mounts on the chassis: (IMG:http://www.originalcustoms.com/invoice/images/large_images/60_042946700%201221191672.jpg) This is SirAndy's oil cooler for his 3.6 914. The cooler is not actually 'mounted' to anything. It's clamped into place with rubber in between the clamps and the cooler. (IMG:http://www.paintandmetal.com/invoice/images/large_images/25_061098100%201157257299.jpg) |
Cap'n Krusty |
Dec 3 2008, 03:41 PM
As I said on the other site where you asked the same question, 3/8ths line isn't gonna get it. It's waaaaaaaay too small, and you're running the risk of destroying your engine. There's a reason they used a 22mm fitting, and it's not because that's what they had laying around. The Cap'n
Dominic |
Dec 4 2008, 06:25 PM
Dominic Group: Members Posts: 992 Joined: 14-January 03 From: Vacaville, CA Member No.: 149 Region Association: Northern California |
Don't go cheap on your oil cooling system, its the heart of your engine.
Try racer parts wholesale, they sell aeroquip fittings and hose at good prices. If not try to find deals here and there on ebay. http://www.racerpartswholesale.com/categor...roquip_Fittings They also have the metric to AN fittings. That 20mm to AN-12/AN-16 (can't recall the size) fitting is available, just do a search. Cheers! |
Lo-Fi Version | Time is now: 9th May 2024 - 10:16 AM |
