to weld or not to weld, vs. POR15 patch |
zeezee |
Dec 3 2008, 09:58 PM
Member Group: Members Posts: 115 Joined: 16-October 08 From: san ramon, ca Member No.: 9,651 Region Association: Northern California |
I have some rust under the seats (surprise!). I had planned to just use "POR15 Patch" on.
But maybe I should get a couple of these patched with steel&weld? Welding is beyond my capabilities so I'd have to find a local shop to do it - I don't like others messing with my car plus $$ (IMG:style_emoticons/default/sad.gif) Opinions? Driversside... Driverside firewall... Pass. firewall/door corner... Possible structural issues with this one... |
Dec 3 2008, 10:07 PM
Resident German Group: Admin Posts: 41,634 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Looks like you had some water sitting on those floor pans for a while ...
That needs to be welded! (IMG:style_emoticons/default/welder.gif) Find someone who is good with a welder and preferably has worked on a 914 before. I'm not sure who's out there with you in "the schticks" but if the car runs, drive it up to Napa and drop it off at McMark's Shop. His work is top notch and affordable. http://www.paintandmetal.com/ (IMG:style_emoticons/default/bye1.gif) Andy |
ericread |
The Viper Blue 914 Group: Members Posts: 2,177 Joined: 7-December 07 From: Irvine, CA (The OC) Member No.: 8,432 Region Association: Southern California |
Looks to me that you don't have much of a choice - that needs to be repaired by welding. If it was the rear trunk area, then who cares? But this is where your Butt sits. You certainly don't to experience a floor failure here.
Eric Read |
Larouex |
Dec 3 2008, 10:08 PM
Larouex Group: Members Posts: 144 Joined: 22-July 08 From: Larouex@gmail.com Member No.: 9,339 Region Association: Pacific Northwest |
I have some rust under the seats (surprise!). I had planned to just use "POR15 Patch" on. But maybe I should get a couple of these patched with steel&weld? Welding is beyond my capabilities so I'd have to find a local shop to do it - I don't like others messing with my car plus $$ (IMG:style_emoticons/default/sad.gif) Looking at the rust you have around the inner-longs and the pan... Have you dug into the hell-hole and other areas on the ourside rockers to get a full evaluation of the rust damage you are dealing with? Having seen a similiar pattern in two cars I have bought, I was optimistic until I really knew all the places. As far a welding goes, it is expensive to have someone do it. You can be your own fixer for a little less than $700.00 and with a little practice, you can tackle a lot of the fixes that you see on these forums. But still you need to know for yourself that your structure is not weakened. Your initial damage in the floorpan looked a lot like mine... <s/> |
Dec 3 2008, 10:14 PM
bbbbbbbbbbb
ConeDodger |
Dec 3 2008, 10:22 PM
Apex killer! Group: Members Posts: 23,584 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
That needs to be welded. I second the McMark nomination... But be warned. He sometimes dresses funny. By the way, someone dropped a bunch of quarters in your car!
LarryR |
Dec 3 2008, 10:26 PM
Senior Member Group: Members Posts: 929 Joined: 15-March 07 From: E. Bay Area, N. California Member No.: 7,604 |
That needs to be welded. I second the McMark nomination... But be warned. He sometimes dresses funny. By the way, someone dropped a bunch of quarters in your car! (IMG:style_emoticons/default/agree.gif) its a bird no its a plane no its super Mark able to weld up rusty 914's in a single bound ... well worth the drop off in napa |
zeezee |
Dec 4 2008, 01:39 AM
That needs to be welded. I second the McMark nomination... But be warned. He sometimes dresses funny. By the way, someone dropped a bunch of quarters in your car! Yes - found lots of goodies: loose change, original open-end wrench, original bolts, nuts, washers, screw hole plugs (all very useful), paint brush, and a finger nail (not so useful) |
VaccaRabite |
Dec 4 2008, 11:25 AM
To big for POR.
Cut and Weld. Zach |
Spoke |
Dec 4 2008, 11:54 AM
As far a welding goes, it is expensive to have someone do it. You can be your own fixer for a little less than $700.00 and with a little practice, you can tackle a lot of the fixes that you see on these forums. (IMG:style_emoticons/default/agree.gif) If you like to work on your own car, buy a welder. By the time you pay someone for those repairs, you will have paid for a welder. It's not hard to learn to weld and it is fun to fix things like this. After I got my welder, I fixed a few items on my 914 and looked around the house for other things I could weld. I've now repaired 4 mufflers: 1 for my 914, one for a BMW, one for a VW bus, and my Audi; mostly hanger repair. |
IronHillRestorations |
Dec 4 2008, 01:37 PM
I. I. R. C. Group: Members Posts: 6,717 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
That's way beyond anything you can buy from POR15. You've got a lot of corrosion there, and I'm 100% sure there's more you haven't found yet, or just can't see. If I was in CA, I'd try to find a solid southern CA donor chassis. Yes, it can be repaired, but it ain't gonna be cheap!
charliew |
Dec 4 2008, 02:27 PM
If I were you I would dig all the sealer out on the inside to make sure thats all you have. The rest of the car needs a real good going over because you might spend 2500.00 and then find even more a little later and before you know it you think you can't afford it. Look for bumps under the vinyl on the top, bubled paint in the door jambs, and any added undercoat from someone before you. Be real sure you check the longs and the hell hole as someone has already mentioned. It already looks like you need to learn how to do metal replacement to make it affordable. Good luck
Todd Enlund |
Dec 4 2008, 02:52 PM
Resident Photoshop Guru Group: Members Posts: 3,251 Joined: 24-August 07 From: Laurelhurst (Portland), Oregon Member No.: 8,032 Region Association: Pacific Northwest |
jd74914 |
Dec 4 2008, 03:42 PM
Yes, it can be repaired, but it ain't gonna be cheap! I'm at $662 in steel and $584 for a welder so far... and that includes some good deals on steel... Don't let that scare you. For me the welder was the most expensive part. I was able to get most of my steel for free from dumps/scrap yards in the form of wrecked car sheet metal. You just can't mind sanding off the original paint or hand-forming your own panels. (IMG:style_emoticons/default/smile.gif) |
zeezee |
Dec 4 2008, 06:02 PM
Sealer has been dug out and there isn't anymore inside - the pictures show all of it. No problems with the "hell hole(s)". I'm afraid to look under the rocker panels.
I guess I'll take the car to a local shop and see what they can do. And start shopping around for a welder and maybe some classes. Thanks for the feedback. |
sww914 |
Dec 4 2008, 06:19 PM
How much do you want for the fingernail? (IMG:style_emoticons/default/smile.gif)
brant |
Dec 4 2008, 10:45 PM
ouch...
a reputable shop really any shop whose work I would care for at all.... is going to make that a 2g repair.... buy a welder and learn to do it yourself. b |
VaccaRabite |
Dec 5 2008, 10:16 AM
Get a welder and just start practicing. Many of us here have done exactly that. Classes are good, but you probably don't need that level of instruction.
Zach |
rjames |
Dec 5 2008, 11:17 AM
I'm made of metal Group: Members Posts: 3,928 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Get a welder and just start practicing. Many of us here have done exactly that. Classes are good, but you probably don't need that level of instruction. Zach If I can do it, anyone can. I took a weekend welding class offered through a local community college. I learned some good things to get me started then practiced a bunch on scrap pieces before touching the car. YOU CAN DO IT! |
zeezee |
Dec 5 2008, 12:05 PM
OK - I'll give welding a try.
What kind of welding am I doing? MIG? Will a $270 arc welder do? http://www.homedepot.com/webapp/wcs/stores...uctId=100041326 |
Lo-Fi Version | Time is now: 12th May 2024 - 09:46 PM |
