Need to tap into a switched fuse |
Slick914 |
Dec 6 2008, 08:23 PM
Member Group: Members Posts: 236 Joined: 10-June 07 From: Lorain, OH Member No.: 7,802 |
Need help figuring out which fuse I can tap into that is switched or only energised when the ignition is on. I don't have a battery installed in the car or I would use a multimeter. This is for a stereo install.
This is a pic I stole from another thread, not mine... (IMG:http://img377.imageshack.us/img377/5862/post21134572507pj7.jpg) |
Slick914 |
Dec 6 2008, 08:29 PM
According to the book fuse #8 is for the wipers, ventilator, horn, and lighter. Are these things powered constantly or switched?
markb |
Dec 6 2008, 10:13 PM
914less :( Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California |
IIRC, red with a white stripe is switched hot. Be careful if you tap into fuse 8. I've driven in the rain a few times & had to use the wipers & the fresh air blower at the same time. Hit the lighter & blew the fuse. If I'd had the stereo hooked in there too, no telling what I coulda burned up.
Slick914 |
Dec 6 2008, 10:39 PM
I did end up hooking into fuse 8. There already was a 2nd spade terminal there that was open. I don't ever plan on having to use the wipers, so I should be safe. If I do get caught in the rain, I'll be sure to turn off the stereo. Worse case senario, the fuse blows.
Lo-Fi Version | Time is now: 20th May 2024 - 09:11 AM |
