clutch cable nuts, what size and thread are they?, misplaced them, new cable, heading to LOWES |
budman5201 |
Dec 7 2008, 11:18 AM
Senior Member Group: Members Posts: 595 Joined: 1-April 07 From: tempe, az Member No.: 7,635 |
anyone know what size/ thread the nuts are on the adjusting end near the transmission. I just installed a new clutch cable and dont want to take it back out to find out.......
Heading to lowes, i appreciate it. |
Dec 7 2008, 11:39 AM
914 Idiot Group: Members Posts: 14,984 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
M7, but I forget the thread pitch. Regular M8 nuts (the ones you use a 13mm wrench on) will hold for about one-half of a press of the pedal, at which point they will let go and fly off, bouncing all around the garage...
--DD |
Larry.Hubby |
Dec 7 2008, 03:42 PM
Member who doesn't post much, but has a long time in 914s Group: Members Posts: 186 Joined: 24-November 04 From: Palo Alto, CA Member No.: 3,172 Region Association: Northern California |
They're 7mm x 1mm pitch.
911quest |
Dec 7 2008, 04:22 PM
Member Group: Members Posts: 277 Joined: 26-March 06 From: Louisville Ky Member No.: 5,773 Region Association: South East States |
GeorgeRud |
Dec 7 2008, 06:18 PM
If you need some, McMaster-Carr stocks that size. I've never seen 7mm nuts at the local hardware stores.
It's one of those parts that would be nice to include with a new clutch cable, as you have a hard time buying just one 7mm nut. I have always used two on my clutch cable so they can be jammed together to prevent movement. Otherwise, a locknut version is required (again, not that easy to find). I haven't tried the local Porsche Dealer, but they may have them in stock (or perhaps the local VW dealer). |
jd74914 |
Dec 7 2008, 06:50 PM
The local Sears Hardware carried 7mm nuts (BTDT).
sww914 |
Dec 7 2008, 08:41 PM
I got some at my local Ace Hardware, a quarter a piece or so.
budman5201 |
Dec 8 2008, 12:38 AM
Lo-Fi Version | Time is now: 12th May 2024 - 02:34 AM |
