budman5201
Dec 7 2008, 11:18 AM
anyone know what size/ thread the nuts are on the adjusting end near the transmission. I just installed a new clutch cable and dont want to take it back out to find out.......
Heading to lowes, i appreciate it.
Dave_Darling
Dec 7 2008, 11:39 AM
M7, but I forget the thread pitch. Regular M8 nuts (the ones you use a 13mm wrench on) will hold for about one-half of a press of the pedal, at which point they will let go and fly off, bouncing all around the garage...
--DD
Larry.Hubby
Dec 7 2008, 03:42 PM
They're 7mm x 1mm pitch.
911quest
Dec 7 2008, 04:22 PM
QUOTE(Larry Hubby @ Dec 7 2008, 01:42 PM)
The same nut that holds the rocker shaft to the head on a type-4
GeorgeRud
Dec 7 2008, 06:18 PM
If you need some, McMaster-Carr stocks that size. I've never seen 7mm nuts at the local hardware stores.
It's one of those parts that would be nice to include with a new clutch cable, as you have a hard time buying just one 7mm nut. I have always used two on my clutch cable so they can be jammed together to prevent movement. Otherwise, a locknut version is required (again, not that easy to find). I haven't tried the local Porsche Dealer, but they may have them in stock (or perhaps the local VW dealer).
jd74914
Dec 7 2008, 06:50 PM
The local Sears Hardware carried 7mm nuts (BTDT).
sww914
Dec 7 2008, 08:41 PM
I got some at my local Ace Hardware, a quarter a piece or so.
budman5201
Dec 8 2008, 12:38 AM
QUOTE(sww914 @ Dec 7 2008, 07:41 PM)
thanks guys.....i ended up cutting and old cable out of my parts car and taking it down. ace hardware!! It was 7x1.00.
thanks again
