front lid latch, locksmith question |
Triaddave |
Dec 7 2008, 04:17 PM
Member Group: Members Posts: 244 Joined: 31-December 03 From: olympia,wa Member No.: 1,478 |
I went to pop the front lid and the handle broke. O.K. so I dug up another handle and went to exchange key cylinders. the broken orginal comes out fine with the key but the unknown has no key. I tried all of the 20-30 keys I have...still can't get it removed. Is there a secret password or something short of a local locksmith?
Triaddave |
Dec 7 2008, 05:25 PM
Is there anybody out there who has done this?
Dec 7 2008, 11:02 PM
914 Idiot Group: Members Posts: 14,984 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
There's a little tiny set-screw in the part of the handle that is inside the housing until you pull on the handle. (I hope I'm not being too confusing about that!) Pull the handle out far enough and you should be able to see it. Put any key in the slot, remove the screw, and the lock cylinder should slide out. Do the same with the old handle so you can put its lock in the new handle.
--DD |
Dec 8 2008, 12:16 AM
question, mine never worked.
What key is supposed to do the front hood lock and the glove box?? Rich |
So.Cal.914 |
Dec 8 2008, 12:20 AM
My Key opens everything.
Sleepin |
Dec 9 2008, 10:21 AM
Advanced Member Group: Members Posts: 3,647 Joined: 20-November 07 From: Grand Junction, Co. Member No.: 8,357 Region Association: Rocky Mountains |
DBCooper |
Dec 9 2008, 10:31 AM
markb |
Dec 9 2008, 10:32 AM
As they stated above, one key should fit all. If not, then look at my signature for how to rekey yours.
So.Cal.914 |
Dec 9 2008, 01:52 PM
Oh for God's sake how could you expect any different. You know I'm a Freak. (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 11th May 2024 - 08:59 PM |
