What's your 914 project this winter?, ....yeah, I know...that's a loaded question |
naro914 |
Dec 11 2008, 10:00 PM
Losing my mind... Group: Members Posts: 2,476 Joined: 26-May 06 From: Charlotte, NC Member No.: 6,073 Region Association: South East States |
So I started going through Huey and getting into the details of where I want him to end up....then i looked across the garage and thought of all the things I need to do to Papa Smurf before the end of March (Road Atlanta Club Race)....
so, off the top of my head: Huey: - -Fix engine leaks - valve covers, chain tensioner, something around the cylinders that worries me a bit, etc. well, not so done...still leaks - - - - - - - - - - -brake bias adjuster -re-wire engine compartment for easy plug and play wires -replace fuse panel with new blade fuses - - -redo dash face - -fix glove box (don't ask) - -GT style carpet? ....that's about for now until I go look at it again tomorrow... For Papa Smurf: -finish scraping floor and interior door "tar" -re-duct front oil cooler to wheel wells -lexan side windows for travel -fix front spoiler (from my agricultural excursion at VIR) - - ....I'm sure I'm missing something. So...these should keep me busy this winter.... What's your projects? |
championgt1 |
Dec 11 2008, 10:15 PM
Don't embarrass me Filmore! Group: Members Posts: 2,680 Joined: 3-January 07 From: Tacoma, Washington Member No.: 7,420 Region Association: Pacific Northwest |
Damn, that's quite the list. I just need to repaint my gas tank, and put it back in the car, replace all the fuel lines and filters, new battery and drive.
slow914 |
Dec 11 2008, 10:17 PM
Member Group: Members Posts: 150 Joined: 5-February 08 From: Kirkland, WA Member No.: 8,671 Region Association: Pacific Northwest |
I was hoping to have my car torn down and well on its way already but without another car my project is still a daily driver, the winter plan is still so get the car painted, possible new floors, 911 front suspension, and a 2270/side shifter running and ready to head down to the WCR by may, wish me luck hahahaha
Chris Pincetich |
Dec 11 2008, 11:12 PM
Hey I was just tinking about this (IMG:style_emoticons/default/beerchug.gif)
With a 914 budget of $0-$100 I want to 1) Learn and perform alignment 2) Raise ride height and grind for more neg camber 3) Re-do interior dash area with nice dash and gauge rings on my shelf 4) Re-do interior strip floors and see how bad rust is 5) Re-do interior strip back and do felt back pad while trying to keep interior light 6 5-point harnesses if I can scrap up more $$ for them and kirkey seats 2008 I rebuilt the 901 and all suspension with needle bearing bushings (IMG:style_emoticons/default/smilie_pokal.gif) Raced once, drove around town 5 times (IMG:style_emoticons/default/unsure.gif) (IMG:style_emoticons/default/rolleyes.gif) (IMG:style_emoticons/default/laugh.gif) I want to put more miles on the 914 in 2009! (IMG:style_emoticons/default/beerchug.gif) |
pete-stevers |
Dec 11 2008, 11:30 PM
saved from fire! Group: Members Posts: 2,641 Joined: 10-October 04 From: Abbotsford,BC, Canada Member No.: 2,914 Region Association: Pacific Northwest |
well so far this winter i have welded on flares with dan roots help
i have just finished the body work( have never done body work before) taped off the car for painting now i have to primer paint and clear. repaint centers on my fuches fit then sand blast a pair of trailing arms to replace the modified ones in the car so i can hook up ebrakes i would like to make WCR this year, instead of haveing her on jackstands |
dkjens |
Dec 11 2008, 11:34 PM
Member Group: Members Posts: 159 Joined: 24-November 08 From: Pasadena, CA Member No.: 9,785 Region Association: None |
'73 914 w. 911SC front suspension and brakes all around.
1. Re-install Chevy SB - mild 283 and stock side shifter 2. Install 9" and 11" GT flares 3. Get new sticker so I can run it on streets again 4. Work all bugs out of her 5. Do a million hours of body work and prep for paint 6. Decide on paint, and paint 7. Get all new rubber mouldings all around $$$$$$ and install 8. Source other 283 or 302 and plan high HP/rev engine rebuild 9. Source parts for 901 tranny upgrade and higher gears Ought to be to hot to do anything after that. |
familienauto |
Dec 11 2008, 11:55 PM
Volksporsche Group: Members Posts: 136 Joined: 5-November 06 From: UW Seattle Member No.: 7,156 Region Association: Pacific Northwest |
Drive it every dry day! Last year roads were clear on Christmas so out we went for a spin with a lot of warm clothing on.
craig downs |
Dec 12 2008, 12:12 AM
Senior Member Group: Members Posts: 768 Joined: 25-November 05 From: mira loma ca. Member No.: 5,189 Region Association: Southern California |
Mine has been a on going project about 2 years solid now and thought it would take only bout 6 months I just want it done.
Its getting close the engine 90% reassembled and the car is almost together after being a shell. Lots of the little things to do and be glad when its done. |
MrKona |
Dec 12 2008, 12:39 AM
Senior Member Group: Members Posts: 597 Joined: 25-July 05 From: Santa Rosa, CA Member No.: 4,469 Region Association: None |
1. Get my 2.0 engine build completed and installed already! (Oh so close...)
1a. Powder coat all sheetmetal. 1b. New rubber seals in engine compartment. 2. Five lug conversion with Fuchs, 16x6 wheels, 1972 911 front struts, brakes. 2a. Repaint struts. 2b. Rebuild front calipers 2c. Have Eric drill rear hubs for five lug. 2d. Acquire tires (Already have the wheels). 3. Install a used stock muffler I just acquired. Needs a media blasting and repaint to original factory gray. 4. Drive my car in 2009. (IMG:style_emoticons/default/driving.gif) |
PeeGreen 914 |
Dec 12 2008, 12:42 AM
Just when you think you're done...wait, there is more..lol Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest |
A lot... I will have a thread with everything I will be doing. So stay tuned (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/drunk.gif)
Todd Enlund |
Dec 12 2008, 02:37 AM
Resident Photoshop Guru Group: Members Posts: 3,251 Joined: 24-August 07 From: Laurelhurst (Portland), Oregon Member No.: 8,032 Region Association: Pacific Northwest |
Kill the rust monster!
Front and rear floor pans * while the pan is out: -- Clutch cable tube repair -- New steel fuel lines Upper and lower wheelhouse Rt engine mount ear Rt suspension console Rt engine tray Engman inner long kit Battery support and tray |
watsonrx13 |
Dec 12 2008, 05:55 AM
Advanced Member Group: Members Posts: 2,734 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States |
This is my list
Red '74 2.0 - link to my website - - - - Rebuild 2.0l FI engine Creamsicle '74 - link to my webside - Install front floor - Repair both rear fenders - Repair engine compartment - Repair exterior longs - - Repair gas tank area - Repair rear trunk area - Remove and clean up front and rear suspension -- Rob This post has been edited by watsonrx13: Apr 6 2009, 04:54 PM |
carr914 |
Dec 12 2008, 06:14 AM
Racer from Birth Group: Members Posts: 118,648 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
naro914 |
Dec 12 2008, 03:09 PM
I stood under Huey a few minutes ago and my list just got longer....
blitZ |
Dec 12 2008, 03:27 PM
Beer please... Group: Members Posts: 2,223 Joined: 31-August 05 From: Lawrenceville, GA Member No.: 4,719 Region Association: South East States |
I have the same list from last winter, which didn't get completed. (IMG:style_emoticons/default/rolleyes.gif)
6freak |
Dec 12 2008, 03:33 PM
My list is short ...put it on dollys cover it and walk away tell spring (IMG:style_emoticons/default/bye1.gif) |
andys |
Dec 12 2008, 03:45 PM
My car is stripped down to the tub, and all the inside surfaces have been painted allowing me to start assembly. With the wheels on the ground and the engine installed, I can start exterior bodywork; got to be ready for WCR!!
Andys |
PanelBilly |
Dec 12 2008, 04:26 PM
914 Guru Group: Members Posts: 5,807 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
Start re-assembly of 914-6 #673. Paint shop told me yesterday, I'll have it back in Febuary.
T.C. AND WHAT FRIDAY WERE THEY REFERING TO? |
thesey914 |
Dec 12 2008, 04:41 PM
Senior Member Group: Benefactors Posts: 1,155 Joined: 1-January 03 From: Staffordshire -England Member No.: 66 |
Done most of what I had planned.
GT Lid (IMG:http://www.thesey.com/pictures/gtlid2.jpg) Fit some struts to replace the torsion bars. (IMG:http://www.thesey.com/pictures/strut1.jpg.jpg) (IMG:http://www.thesey.com/pictures/strut2.jpg.jpg) (IMG:http://www.thesey.com/pictures/strut3.jpg.jpg) (IMG:http://www.thesey.com/pictures/strut4.jpg.jpg) (IMG:http://www.thesey.com/pictures/strut5.jpg.jpg) (IMG:http://www.thesey.com/pictures/bootlid.jpg) |
jsayre914 |
Dec 12 2008, 04:47 PM
Speed Up !!! Group: Members Posts: 3,188 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
HMMMMMMM. MY LIST...
FIX BATTERY TRAY (LIL WELDING) REPLACE AND SPRAY FRONT HOOD PERTRONIX/ PLUGS/ WIRES/ CAP ETC VALVE JOB OIL CHANGE SUPER SOUND SYSTEM INSTALL NEW TIRES HEAT TURBO TIE ROD NEW BUSHINGS FRONT A-ARM AND SWAY JEEP BUILD 12V (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 04:06 AM |
