| rfuerst911sc |
May 9 2009, 02:55 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States |
I just wanted to say I have purchased most of the items he makes and have recently started installing them. Great quality, fit and price (IMG:style_emoticons/default/beerchug.gif) Don't hesitate to buy these products.
| Tom_T |
Jun 7 2009, 04:13 PM
TMI.... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,321 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California
Well, I finally put together a package of all the seals I have here's the list : Here's the list of what I've got Lower windshield to dash seal # 914-552-263-10 $22.00 Windshield exterior seal $20 replaces chrome Outer door seals #914 531 813/4 10 $70 Targa top lower front seal #914-563-319-10 $30.00 Engine seal set of 4 $72.00 Inner door seals #914-531-821/2-10 $32.00 Fender seals "T" type (2) 914-559-155-10 $7.00 Vertical targa seals (2)kit 914-531-143/4-10 $16.00 Rear targa seal 914-563-077-11 $40.00 Outer door to window seals (2) 914-531-873/4-10 $13.00 Rear Trunk Seal (front) 914-512-317-10 $14.00 Rear Trunk Seal main 914-512-317-10 $30.00 Front main trunk seal 914-511-901-10 $60.00 front trunk seal (main) with bulkhead $75.00 (both seals) front blukhead seal only 914-511-902-10 $18 Targa to window seals (2) 914-531-185-10 $38.00 Repair for 3 part main targa seal $36.00 Engine decklid seal 2 part seal $22 1 part $26 A list of other stuff Seat handle adjusters black (2) $40.00 Heater hose set (2) 930-211-622-01 $28.00 Early Front bumper tops 914-503-023-10 $318 Set of 50 stainless allen sheet metal screws with washers $20 Hey Mikey - can you post some pix of the outside & inside of that F bumper top strip that I highlighted in red above pleeeez!? If you already did so at another link, then give that unless you want to post that here too. ...did you end up using SS on the internal stiffeners & studs/bases for that top strip??? Any ETA on your L&R front rubber "tits" (bumper guards)? ...& rear bumper rubber top strip? Pleeeez post pix of those when ready too! Thanx!! |
| barada |
Jun 13 2009, 08:52 AM
Member ![]() ![]() Group: Members Posts: 257 Joined: 5-October 08 From: Atlanta Member No.: 9,613 Region Association: None |
I need these.
The engine lid seal worked out great. Fender seals "T" type (2) 914-559-155-10 $7.00 Vertical targa seals (2)kit 914-531-143/4-10 $14.00 Outer door to window seals (2) 914-531-873/4-10 $13.00 Targa to window seals (2) 914-531-185-10 $38.00 Thanks Phillip |
| Jerry75914 |
Jun 20 2009, 07:15 PM
Member ![]() ![]() Group: Members Posts: 124 Joined: 13-October 08 From: Half Moon Bay, CA Member No.: 9,640 Region Association: Northern California |
I just received my engine decklid seal, and if I didn't know better I would swear it is an OEM part. Absolutely fantastic product!!! (IMG:style_emoticons/default/smilie_pokal.gif) This will be the first place I look for ANY seal I need. Fantastic!
| Mikey914 |
Jun 22 2009, 01:24 PM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,786 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
Thanks Jerry, more new stuff on the way!
| ghuff |
Jun 22 2009, 03:10 PM
This is certainly not what I expected down here. ![]() ![]() ![]() Group: Members Posts: 849 Joined: 21-May 09 From: Bodymore Murderland Member No.: 10,389 Region Association: MidAtlantic Region |
Rear Trunk Seal (front) 914-512-317-10 $14.00 Rear Trunk Seal main 914-512-317-10 $30.00 front blukhead seal only 914-511-902-10 $18 Fender seals "T" type (2) 914-559-155-10 $7.00 Outer door to window seals (2) 914-531-873/4-10 $13.00 Do you have the A-pillar seals that sit in the chrome and go against the triangle door windows? Do you have the seals that go in the sail panel chrome trim and go against the window? Sending you a PM with my email |
| rick 918-S |
Jul 6 2009, 06:29 AM
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,371 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region
(IMG:style_emoticons/default/bye1.gif) Mike, I didn't see the link to your web site. can you post it?
| geniusanthony |
Jul 6 2009, 05:01 PM
Its a brand new "Chrome-sicle" ![]() ![]() ![]() Group: Members Posts: 517 Joined: 12-December 05 From: Alexandria,VA Member No.: 5,266 Region Association: MidAtlantic Region |
914rubber.com
| Mikey914 |
Jul 6 2009, 09:47 PM
I do give my best pricing here, so drop me a PM or use the contact form on the site.
Thanks, Mark |
| '73-914kid |
Jul 25 2009, 05:26 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,473 Joined: 1-November 08 From: Vista, CA Member No.: 9,714 Region Association: Southern California |
Just recieved the engine bay seal set and door handle seals. the quality is excellent. very impressed.
One question, the seals seem very long, are they meant to be cut to size/ perfect fit? |
| Mikey914 |
Jul 26 2009, 06:25 PM
Yes I do provide them and most of my seals slightly longer than you will need them. I have recieved seals in the past and thought if these were just 1/8" longer they'ld fit perfectly. Well now they'll fit your car as well as you want them to.
Thanks again, Mark |
| tat2dphreak |
Aug 4 2009, 06:59 PM
stoya, stoya, stoya ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
are all of your seals/products on your website?
I'm about to go ape-shit on seal buying, and get a ton at once. |
| ghuff |
Aug 4 2009, 07:11 PM
Mikey914, can you see my post above? I sent you a PM with the same contents. I need all of those seals.
Thanks! |
| Mikey914 |
Aug 5 2009, 11:48 AM
Sorry I thought I had responded. Been kind of crazy lately. I'll get you an invoice this afternoon wen I'm back in the office. Sorry for the delay.
| ghuff |
Aug 5 2009, 01:07 PM
| westo2 |
Aug 7 2009, 09:57 AM
Member ![]() ![]() Group: Members Posts: 53 Joined: 6-February 08 From: Buffalo Member No.: 8,672 Region Association: North East States |
Hi Mark,
I'm looking for the: full front trunk seal w/ Bulkhead seal rear main trunk seal and I assume the fender seals "t" type are the cowl seals in front of the windshield? If so, I'll take a set of those as well. Also, I just replied on your pre sale for the 3 part main targa seal. Thanks! |
| steveherman |
Nov 4 2009, 12:35 AM
Member ![]() ![]() Group: Members Posts: 380 Joined: 12-September 09 From: Kissimmee Florida Member No.: 10,799 Region Association: South East States |
pm sent
| budman5201 |
Nov 7 2009, 12:35 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 595 Joined: 1-April 07 From: tempe, az Member No.: 7,635 |
does your windshield to dash seal have the steel clamp on the inside so it just clamps around the stock channel or do i have to glue it in??
I am also interested in the one for the back window to engine lid if it has the clamp also.... thanks, CHris |
| Mikey914 |
Nov 7 2009, 09:55 PM
does your windshield to dash seal have the steel clamp on the inside so it just clamps around the stock channel or do i have to glue it in?? I am also interested in the one for the back window to engine lid if it has the clamp also.... thanks, CHris The rear has an aluminum clip so it will not rust. The front is made from Santoprene (better for the high temps in the sun) with a low clearance opening. I could have put the clip in, but it makes it harder to install with the windshield in. This seal is kept in place mainly by the close tollerence on the opening, but I cut mine about 1/8" longer than it needed to be and installed the corners first working my way to the center. This causes it to "over-center" and help hold it into place too. As it's not really a "seal" and a cosmetic piece it work out fine. Mine is also about 1/16" larger than stock making it hide the edge of the vinyl better. Hope this helps. |
| steveherman |
Nov 16 2009, 10:15 PM
HEY Mark
i am working on my shopping list for you. can you update your list with everything you that you are now producing so i can do this once. thanks steve |
Lo-Fi Version | Time is now: 8th November 2026 - 12:10 AM |
