Installed the eurorace tonight..... |
KaptKaos |
Dec 28 2008, 08:47 PM
Family Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest |
So I installed the used eurorace tonight, I used the supertrapp that came with it.
It's loud for sure, and it revs so much more easily and it revs up to 6k without trouble now. My motor is a 1911 with an unknown carb cam in there. I got it used, but it runs nicely. Anyway, while it pulls nicely, when I am running on the idles or on over-run, it pops like a popcorn maker!! I am running 44idfs on the 1911, and it does run a little rich too, but wow it really pops alot. I Plan to get back under and check the bolts to ensure that they are all tight. I want to make this popping go away so what else should I be looking for? TIA |
ericread |
Dec 28 2008, 08:51 PM
The Viper Blue 914 Group: Members Posts: 2,177 Joined: 7-December 07 From: Irvine, CA (The OC) Member No.: 8,432 Region Association: Southern California |
Check for this guy in your carb.
He tends to make a lot of "Popping" noises... (IMG:style_emoticons/default/lol3.gif) |
wallys914 |
Dec 28 2008, 09:00 PM
In life you don't get what you want, you get what you negoia Group: Members Posts: 190 Joined: 10-October 08 From: Garden Grove, Member No.: 9,631 Region Association: Southern California |
Chinese or American Webers?
Does the popping clear out after 3500-4000rpm? Pull your idle jets and check them, blow them out if need be, most always the idle jets when popping, between 1000-3500rpm. Just my expierence... |
KaptKaos |
Dec 28 2008, 09:27 PM
Chinese or American Webers? Does the popping clear out after 3500-4000rpm? Pull your idle jets and check them, blow them out if need be, most always the idle jets when popping, between 1000-3500rpm. Just my expierence... Umm.... Italian I believe. I will check the idles tomorrow, as it really is bad when on the idle circuit alone. |
wallys914 |
Dec 28 2008, 09:33 PM
Look through them and im sure you will see something blocking the hole.
DBCooper |
Dec 29 2008, 06:09 AM
No pops before? Did you change anything in the linkage or the timing at the same time you put on the new exhaust? If not then it's almost certainly exhaust leaks, especially if you're generally running rich. The carburetors are are pretty much out of the equation on overrun, so is the popping any worse on acceleration or deceleration?
It's easy enough to check jets, so do that first because it might be both, but I think you're probably going to end up spending some more time under the car. |
Joe Ricard |
Dec 29 2008, 07:08 AM
popping on over run is exhaust leak
KaptKaos |
Dec 29 2008, 10:10 PM
Blew out the idles.
Tightened the intake manifolds. Tightened most of the exhaust studs. It's still happening. In fact, I am getting flames out of the tail pipe !!!! So I will likely drop each segment and make sure the mating surface is true. I should replace the copper gaskets while I am in there shouldn't I? Ugh...... They were a biatch to get out last time. Oh joy. Any other ideas? |
jsayre914 |
Dec 29 2008, 10:20 PM
Speed Up !!! Group: Members Posts: 3,188 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
flames like this (IMG:style_emoticons/default/biggrin.gif)
justme |
Dec 29 2008, 10:25 PM
Member Group: Members Posts: 187 Joined: 1-January 07 From: southampton ma atlantic northeast Member No.: 7,413 Region Association: North East States |
(IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) |
KaptKaos |
Dec 29 2008, 10:34 PM
More like this:
http://www.youtube.com/watch?v=QYW89sBBKpo But seriously, it is flaming out of the back. Not happy about that. (IMG:style_emoticons/default/sad.gif) |
VaccaRabite |
Dec 30 2008, 03:05 PM
En Garde! Group: Admin Posts: 13,444 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
You are a bit rich, eh?
You may have a little leak at the collector too (seems to be common with the Eurorace - mine has one there). When I bought mine, it also had a bad weld at one of the seams, that I re welded shut. The fabricator just had not welded it all the way around. Zach |
KaptKaos |
Dec 30 2008, 08:01 PM
(IMG:style_emoticons/default/mad.gif) (IMG:style_emoticons/default/mad.gif) (IMG:style_emoticons/default/mad.gif) (IMG:style_emoticons/default/mad.gif) (IMG:style_emoticons/default/mad.gif) (IMG:style_emoticons/default/mad.gif) (IMG:style_emoticons/default/mad.gif)
Broke an exhaust stud trying to button things up. Only the top, so I should be able to back it out. Still sucks. More to follow..... |
Lo-Fi Version | Time is now: 19th May 2024 - 12:56 PM |
