914.356.202.00 - Rubber Sleeve, ...for main fuel line running through the rear fire wall |
Zimms |
Dec 28 2008, 09:12 PM
Senior Member Group: Members Posts: 1,413 Joined: 11-February 06 From: Michigan Member No.: 5,565 Region Association: Upper MidWest |
I tore this part and started to look for a repacement at all of the typical sources, PP, AA, GPR, adn even the local dealer. The PET catalog calls this part out as a "rubber Sleeve". A search on these sites and the dealer for this part number brings up a "Drain Brush" and it is NLA. In the long run, I can just use the return line part, 914.356.201.00 and take material out of the ID to match the main line diameter.
BUT, now I am curious. The 914.356.201.00 is readily available. Why would one be available and the other not? Why the difference in description from the PET to "Drain Brush"? Both parts had another set of numbers molded into the top lip along with the part number. They didn't help me track down the original, but they are: 914.356.201.00 - 48107 2 33 914.356.202.00 - 48107 A2 24 Anyone else run across this? |
914werke |
Dec 29 2008, 02:15 AM
"I got blisters on me fingers" Group: Members Posts: 10,037 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
picture?
Zimms |
Dec 29 2008, 06:55 AM
914.356.202.00 on the left. 914.356.201.00 on the right. Physical dimensions are identical except for the ID. |
AvalonFal |
Dec 29 2008, 05:01 PM
Member Group: Members Posts: 483 Joined: 3-July 05 From: Southern New Jersey Coast Member No.: 4,367 Region Association: MidAtlantic Region |
The AA catalog shows both sizes available - page 44.
Paul |
Lavanaut |
Jan 6 2009, 03:45 PM
Hungry Mind : Thirsty Gullet Group: Members Posts: 916 Joined: 20-June 06 From: Bend, OR Member No.: 6,265 Region Association: Pacific Northwest |
dc Automotive claims to have one, used, for $5:
http://dcauto.gotdns.com/illustration/index/2431312 It *does* show up in the PP catalog as "rubber sleeve", NLA, but it's in the 911 catalog. AA shows it used as "rubber sleeve", $5.50, new "drain brush".. $1. (IMG:style_emoticons/default/biggrin.gif) Of course that doesn't necessarily mean they have either in stock. The "drain brush" label is probably just an error that's been propagated over the years. Let us know what you find! |
Zimms |
Jan 8 2009, 03:24 PM
No luck. I had e-mailed PP and they told me it was NLA. I ordered one from AA since it was listed on the website, but got an e-mail today that it is indeed, NLA. I thought the price difference was odd, but for $1 I figured the worst case is I would find out what a drain brush was.
It's odd that there are two identical parts except for the ID, and one is NLA. Maybe the mold was dropped? |
McMark |
Jan 14 2009, 12:55 AM
Larger fuel line = more mass = more vibration damage = more replaced parts.... (IMG:style_emoticons/default/idea.gif) maybe...
IronHillRestorations |
Jan 14 2009, 09:57 AM
I. I. R. C. Group: Members Posts: 6,716 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
I got some of those from Porsche about eight months ago. They only have one size, the larger one, and it's a hard plastic not rubber. I'll take a pic if I get the chance.
914Sixer |
Jan 15 2009, 08:23 PM
914 Guru Group: Members Posts: 8,875 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
I got 2 of the 9mm (larger one) a couple of months ago from Porsche. The 7mm (smaller one) is NLA. I need to look for something from West Coast Metric that will cross over from VW. I bet there is something we can use.
Lo-Fi Version | Time is now: 4th May 2024 - 11:32 AM |
