Stripped CV Bolt, New Method for removal |
turnaround89 |
Dec 30 2008, 12:28 PM
Senior Member Group: Members Posts: 671 Joined: 17-May 08 From: Rockford, Illinois Member No.: 9,067 Region Association: Upper MidWest |
Last night i got 7 of 8 cv bolts removed and one of them was stripped, so i tried all the methods you guys mentioned, vise grips, weld a bolt on the end. Nothing worked.
I now have an easier method to getting them out, you will have to sacrifice that stripped bolt, but oh well, because you throw it out anyway since its stripped. What i did was pull the wheel off(better access if you have flares on the car) and took a dremel to the cv bolt. Ground a two flats on the bolt so i could get a wrench on it. Took 20 minutes to grind the bolt flat on two opposing sides. I ground the thing down to about an 11mm wrench size. Wasn't perfect but worked ridiculously well. After I got the bolt loosened up, i used vise-grips to keep loosening the bolt. Hope this helps someone!! |
Lo-Fi Version | Time is now: 19th May 2024 - 02:53 PM |
