Last night i got 7 of 8 cv bolts removed and one of them was stripped, so i tried all the methods you guys mentioned, vise grips, weld a bolt on the end. Nothing worked.
I now have an easier method to getting them out, you will have to sacrifice that stripped bolt, but oh well, because you throw it out anyway since its stripped. What i did was pull the wheel off(better access if you have flares on the car) and took a dremel to the cv bolt. Ground a two flats on the bolt so i could get a wrench on it. Took 20 minutes to grind the bolt flat on two opposing sides. I ground the thing down to about an 11mm wrench size. Wasn't perfect but worked ridiculously well. After I got the bolt loosened up, i used vise-grips to keep loosening the bolt.
Hope this helps someone!!
