> What to do to 2.0L Heads?, For performance and reliability
ThinAir
post Feb 16 2004, 11:02 PM
Best friends
Well I've gotten started on rebuilding the 2.0L 4 cylinder engine that was in the car when I got it. I got it all torn down last week and on Saturday I got the case in to Competition Engineering to have them ensure that when the lifters went bad they didn't damage the case.
So looking ahead... what would you do to the heads to help with creating a solid daily driver that gets the most output (both horsepower and mpg) out of a stock FI 2.0L with Euro pistons in it?
Jake Raby
post Feb 16 2004, 11:12 PM
Engine Surgeon
Stock rebuild
12mm plug modifcation
42x36 valves
single H/D springs
Bleyseng
post Feb 16 2004, 11:13 PM
Aircooled Baby!
Send them to HeadflowMasters and have them rebuilt and ported.
Geoff
ThinAir
post Feb 16 2004, 11:29 PM
Best friends
http://www.audiracvws.com/914porscheracingheads.htm is this the right address for HeadflowMasters?
swood
post Feb 17 2004, 12:02 AM
Yup.
Mike9142.0
post Feb 17 2004, 09:22 PM
Why 12 spark plugs?
Jake Raby
post Feb 17 2004, 09:28 PM
Engine Surgeon
It reduces the chamber cracks by 90% easily... Its standard for all my 2.0 heads. The 2.0 chamber is terriable for cracks. Get it hot once and its cracked-
ChrisReale
Sleazy
QUOTE(Mike9142.0 @ Feb 17 2004, 07:22 PM)
Why 12 spark plugs?
Jake has all the poop on this, but I believe it has something to do with making the spark plug holes stronger so they dont crack as easily, as the 2.0L heads are known to
ThinAir
post Feb 17 2004, 10:19 PM
Best friends
QUOTE(Jake Raby @ Feb 16 2004, 10:12 PM)
So just exactly what is this? Does this mean you are using a larger size spark plug or is it more like an insert in the head so that the spark plug isn't directly threaded into the head?
Dave_Darling
post Feb 17 2004, 10:37 PM
914 Idiot
Smaller spark plug. Weld up the hole in the head, drill and tap for a smaller spark plug. Smaller hole == more material around the hole == less chance of cracking.
Doesn't do jack for the short radius of the exhaust port, which is the other place where 2.0 914 heads like to crack... (IMG:style_emoticons/default/sad.gif)
--DD
ThinAir
post Feb 17 2004, 10:43 PM
Best friends
Does the smaller hole limit your selection of plugs or are you still able to get plugs in the correct temperature range?
Jake Raby
post Feb 17 2004, 11:54 PM
Engine Surgeon
A Ducati motorcycle uses the exact same heat range as my engines do... They are 12mm and available in NGK
Zeke
post Feb 18 2004, 12:19 AM
Never left, but not right....
There isn't one part of the type4 that Jake hasn't fooled with. Ducati plugs. Next thing will be Volvo pistons, Mecedes rods, an oil pump from a Caterpillar, heads from a 911 and EFI from some GM machine. (IMG:style_emoticons/default/rolleyes.gif)
Jake Raby
post Feb 18 2004, 12:31 AM
Engine Surgeon
There are TONS of things that we have not learned yet.. I learn atleast one big thing a week on average... When you stop learning- its because you are dead or dying!
The TIV has many mysteries- just wait till my new heads are done and the key to the power door will be opened really wide- and they'll cool too!
- Lo-Fi Version Time is now: 13th July 2025 - 10:29 AM
