Paint Removal Question, PO painted wheels! |
JC 914 |
Jan 1 2009, 11:49 AM
Member Group: Members Posts: 124 Joined: 21-June 07 From: Johnson City,TN Member No.: 7,827 |
PO painted Rivieras to match pinstriping. What is the best way to remove without damaging finish?
Attached thumbnail(s) |
Gint |
Jan 1 2009, 12:18 PM
Mike Ginter Group: Admin Posts: 16,075 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Good question. I don't think there is going to be an easy way without comprising the remaining finish. You could tape them off and paint the painted areas black.
I kinda like the look (on the wheels that is). |
type47 |
Jan 1 2009, 02:34 PM
i used Easy-Off oven cleaner to remove some paint from some VW 5-spoke alloys. can't vouch for not harming the finish though.
rfuerst911sc |
Jan 1 2009, 03:30 PM
Advanced Member Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States |
I would think a liquid/paste type paint remover should work. You might want to mask off the wheel to be safe and use a small brush to neatly apply the remover. I don't believe this would hurt the OEM finish which should be anodized.
tod914 |
Jan 1 2009, 04:21 PM
If your changing the white areas to black, go with Gint's suggestion. Why risk staining the metalic finish.
PeeGreen 914 |
Jan 1 2009, 04:35 PM
Just when you think you're done...wait, there is more..lol Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest |
If your changing the white areas to black, go with Gint's suggestion. Why risk staining the metalic finish. (IMG:style_emoticons/default/agree.gif) I too actually like the subtle accent. |
tod914 |
Jan 1 2009, 10:46 PM
Here's with the black centers. White looks good.
ericread |
Jan 1 2009, 11:04 PM
The Viper Blue 914 Group: Members Posts: 2,177 Joined: 7-December 07 From: Irvine, CA (The OC) Member No.: 8,432 Region Association: Southern California |
Here's my tired old wheels with a bad overspray paint job by the PO:
And here they are after I did a really light amount of sanding with 250 Grit sandpaper: Eric |
McMark |
Jan 2 2009, 02:19 AM
Try brake cleaner first. If it's cheap paint (rattle can), it'll come right off.
JC 914 |
Jan 3 2009, 04:16 PM
Just a quick bump in case there are any other suggestions. |
Lo-Fi Version | Time is now: 19th May 2024 - 03:42 PM |
