JC 914
Jan 1 2009, 11:49 AM
PO painted Rivieras to match pinstriping. What is the best way to remove without damaging finish?
Gint
Jan 1 2009, 12:18 PM
Good question. I don't think there is going to be an easy way without comprising the remaining finish. You could tape them off and paint the painted areas black.
I kinda like the look (on the wheels that is).
type47
Jan 1 2009, 02:34 PM
i used Easy-Off oven cleaner to remove some paint from some VW 5-spoke alloys. can't vouch for not harming the finish though.
rfuerst911sc
Jan 1 2009, 03:30 PM
I would think a liquid/paste type paint remover should work. You might want to mask off the wheel to be safe and use a small brush to neatly apply the remover. I don't believe this would hurt the OEM finish which should be anodized.
tod914
Jan 1 2009, 04:21 PM
If your changing the white areas to black, go with Gint's suggestion. Why risk staining the metalic finish.
PeeGreen 914
Jan 1 2009, 04:35 PM
QUOTE(tod914 @ Jan 1 2009, 02:21 PM)
I too actually like the subtle accent.
tod914
Jan 1 2009, 10:46 PM
Here's with the black centers. White looks good.
ericread
Jan 1 2009, 11:04 PM
Here's my tired old wheels with a bad overspray paint job by the PO:
Click to view attachmentAnd here they are after I did a really light amount of sanding with 250 Grit sandpaper:
Click to view attachmentEric
McMark
Jan 2 2009, 02:19 AM
Try brake cleaner first. If it's cheap paint (rattle can), it'll come right off.
JC 914
Jan 3 2009, 04:16 PM
Just a quick bump in case there are any other suggestions.
