My paint didn't match, I'm going to be an expert at sanding clearcoat |
PanelBilly |
Jan 2 2009, 09:18 PM
914 Guru Group: Members Posts: 5,807 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
First time I applied the paint, it came out light blue. I'm after gulf blue. I wasn't happy with the application (my first attempt) so I sanded it off and repainted. Then I went to do the doors trunk and trunk. I wasn't happy with that job either. So I sanded that one down and reapplied another coat this weekend.
Now the first coat was light blue, the second was a shade darker and the next two have been light again. My friend who paint cars for a living is lost as to how I managed to change the tint from light to dark to light again. I've been using all the same product. At this point I don't have enough paint to do it again, so he's going to mix up a batch to match the body and I get to sand down the clearcoat on the parts I just finished. Are we having fun yet? Photos are already posted on What did you do on New Years Day thread (IMG:http://www.914world.com/bbs2/uploads/post-6488-1230924580.jpg) (IMG:http://www.914world.com/bbs2/uploads/post-6488-1230924593.jpg) |
burton73 |
Jan 3 2009, 01:21 AM
burton73 Group: Members Posts: 3,524 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
Did they mix you one gallon of paint or 4 quarts. I Painted a 911 SC and they mixed color in each can. They told me to put all the color in the paint pot, mix and pour it back in the cans so it would all be the same. What is your story on the mixing of the color?
Bob |
sww914 |
Jan 3 2009, 01:50 AM
The white pigment in light blue is really heavy. It will sink to the bottom pretty fast. If you stirred it plenty the first time, not quite enough the second time and then plenty again the third time it could cause what you've described. I generally stir the paint about twice as much as I think it really needs jsut to be sure that that doesn't happen to me again. I had to repaint an entire Southern California Edison crane truck once because I didn't stir the paint enough. I only did that once. (IMG:style_emoticons/default/mad.gif) (IMG:style_emoticons/default/mad.gif) (IMG:style_emoticons/default/mad.gif)
McMark |
Jan 3 2009, 02:32 AM
My painter only paints cars mock-up assembled to make sure the panels match. Trunks, underside/inside of doors and lids, and jambs in one paint job, then he puts on all the lids/doors, tapes off the jambs/trunks and paints the outside.
scotty b |
Jan 3 2009, 08:49 AM
It happens (IMG:style_emoticons/default/sad.gif) and it usually happens when the parts are painted seperately. This can be due to several reasons most of which have already been stated.
Mix all of your paint ( base coat ) together, Shake it well before shooting, agitate the gun while you are shooting ( inbetween coats ) and if at all possible, shoot EVERYTHING together. Assuming you are happy with your door jambs, you might should re-hang and align your panels now, and re-shoot the whole car one more time assembled. Yes you will need to tape off your jambs buit if it gets you and even color it will be worth it. Something most people do not know is the humidity, and temp to some degree, will also affect the final color. I try my best to avoid painting on really humid days. ( most of the summer in Va) |
jmmotorsports |
Jan 4 2009, 07:41 PM
Member Group: Members Posts: 308 Joined: 15-August 06 From: Kelso,Wa. Member No.: 6,658 Region Association: Pacific Northwest |
Hey Billy,
Now you know why we charge what we do for quality paint work. It will get easier after you do a few hundred. Keep at it,it will be beautiful. Jerry |
Jan 4 2009, 07:52 PM
It happens (IMG:style_emoticons/default/sad.gif) and it usually happens when the parts are painted seperately. This can be due to several reasons most of which have already been stated. Mix all of your paint ( base coat ) together, Shake it well before shooting, agitate the gun while you are shooting ( inbetween coats ) and if at all possible, shoot EVERYTHING together. Assuming you are happy with your door jambs, you might should re-hang and align your panels now, and re-shoot the whole car one more time assembled. Yes you will need to tape off your jambs buit if it gets you and even color it will be worth it. Something most people do not know is the humidity, and temp to some degree, will also affect the final color. I try my best to avoid painting on really humid days. ( most of the summer in Va) Expecially Red. (IMG:style_emoticons/default/laugh.gif) |
PanelBilly |
Jan 4 2009, 08:54 PM
All in all, I have to admit that I'm having fun and when its done, (if ever!), I have something to take pride in. Ye-sterday and today I reprep'd the doors, hood and trunk. My freind is going to try mix up a batch to match the body shell. Hopefully by next weekend I'll have a car that's all the same color.
Anybody need some clearcoat dust? I have a good supply of it. |
craig downs |
Jan 4 2009, 10:34 PM
Senior Member Group: Members Posts: 768 Joined: 25-November 05 From: mira loma ca. Member No.: 5,189 Region Association: Southern California |
I wish you the best of luck and hope it turns out great this time.
charliew |
Jan 5 2009, 05:13 PM
Try doing artic white with blue pearl midcoat and clear. Throw in doing the body with doors, then the fenders and hood and trunk on different days outside with the wind blowing and a good supply of bugs in the pearl and clearcoat. Talk about extra paint and trying to match up the pearl tint. Very expensive and time consuming and frustrating. Not to mention sanders shoulder. Don't you love it?
sixnotfour |
Feb 1 2009, 01:40 PM
914 Wizard Group: Members Posts: 10,432 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
pete-stevers |
Feb 1 2009, 02:00 PM
saved from fire! Group: Members Posts: 2,641 Joined: 10-October 04 From: Abbotsford,BC, Canada Member No.: 2,914 Region Association: Pacific Northwest |
looks like you are one up on me..you are in a booth..i am dong mine in the barn( read plastic walled spray booth
i have more than a few imperfections....but mostly it will polish out |
Lo-Fi Version | Time is now: 18th May 2024 - 02:30 AM |
