New Project: Grassroots Motorsports $2010 Challenge Car |
camaroz1985 |
Jan 6 2009, 03:09 PM
Member Group: Members Posts: 90 Joined: 17-December 08 From: Bressler, PA Member No.: 9,857 Region Association: None |
Just thought I would post up a quick picture of my newest project.
(IMG:http://i254.photobucket.com/albums/hh87/camaroz1985/914/PIC-0088.jpg) Its a '75 that I will be building for the $2009 Challenge. There is no engine now, and I am still trying to figure out what I will be using. I think about 200hp should be good enough if I can keep the weight down. I figure I have about $750 for engine and cooling system (or preferably a parts car that I can get everything from). What do you guys think? What are my best options? Who has cheap parts they want to sell to help the cause (IMG:style_emoticons/default/biggrin.gif) I'll update this as I progress. |
camaroz1985 |
Jan 7 2009, 11:12 AM
What about a NA Subaru 2.5 with a FWD transmission. I can cut the axles to the 914 and Subaru, machine them and weld together (as was discussed above). For the engine I would use reground higher lift cams (from Delta Camshaft), shave the head for higher compression, run WRX injectors, and a high flow pump, and feed it with E85. E85 will work well with the higher compression and allow me to run more timing (using a piggyback EMS). It will also run cooler than with gas.
I think I can do this within the budget and make maybe 200-220hp. |
Lo-Fi Version | Time is now: 25th May 2024 - 01:58 PM |
