Any tips on getting the Fs&^ing roll pin in, Pedal cluster designed by an arse |
veltror |
Jan 15 2009, 04:41 PM
Senior Member Group: Members Posts: 928 Joined: 27-April 08 From: Potters Bar Herts UK Member No.: 8,978 Region Association: None |
Is there some amazing way I can get the roll pin into the pedal clusetr? I have tried sticking it in the freezer for a few days but no joy or do I need a bigger (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif)
Cheers Roman |
TravisNeff |
Jan 15 2009, 04:44 PM
Do you have a vice or a hydraulic press?
I tried (with some extra hands) putting the cluster in a vice, one site of the roll pin I put a socket and the other side a small bolt - then press it out. Don't try to drill the thing out! |
So.Cal.914 |
Jan 15 2009, 04:47 PM
I have tapered one end of the roll pin with a grinder just enough to get it started.
Mr Shea I'm sure has a trick. |
VaccaRabite |
Jan 15 2009, 04:52 PM
En Garde! Group: Admin Posts: 13,444 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I used a vice as a makeshift press. I also warmed up the boss it goes into with a MAPP torch. Easy.
Zach |
Jan 15 2009, 05:03 PM
Its just a matter of getting it straight to start with...and use a punch, not a nail set...a punch the correct diameter of the pin or you peen over the end of the pin.
One end should have a slight taper...maybe both. If not, get a grinder or hand file and taper the end a bit...just a slight camfer. Rich |
andys |
Jan 15 2009, 05:09 PM
I'd like to ask why you can't replace the roll pin with a high grade metric bolt with the unthreaded shank running nearly the whole required length?
Andys |
Wes V |
Jan 15 2009, 06:05 PM
Member Group: Members Posts: 482 Joined: 11-October 07 From: Los angeles Member No.: 8,211 |
On Honda's, the shift linkage is attached at the transmission with a roll pin. It's commonly refered to as the "bitch pin" by anybody that has to deal with it.
Here is a write-up that I did showing how to do it without getting out the BFH: "removing a bitch pin" It may give you some ideas. Andys; One of the ideas behind roll pins is that they are in tight contact on the sides. This prevents any movement between the two items. If you used a bolt and the sides were not tight, you would have to tighten the nut to the point that you crush the outer piece tight against the inner piece. Of course this requires that both items have pretty much the same inside diameter. I doubt it makes any difference on a brake pedal assembly!! I'd also guess that P uses a roll pin in this location due to cost for parts and labor time being less. Wes |
veltror |
Jan 15 2009, 06:33 PM
Right , I 'll give this another go tomorrow. thanks for the advice.
R |
Eric_Shea |
Jan 15 2009, 08:26 PM
Vise works. Press works slightly better but it's hard to position.
ericread |
Jan 15 2009, 08:49 PM
The Viper Blue 914 Group: Members Posts: 2,177 Joined: 7-December 07 From: Irvine, CA (The OC) Member No.: 8,432 Region Association: Southern California |
When I rebuild my cluster, I asked the same question. The answer was "BFH"
Worked for me. Eric Read |
Eric_Shea |
Jan 16 2009, 01:43 AM
BFH to get the roll pin in?
ericread |
Jan 16 2009, 10:37 AM
BFH to get the roll pin in? Yep. A few dozen taps and it scooted right in. (IMG:style_emoticons/default/smash.gif) |
IronHillRestorations |
Jan 16 2009, 12:19 PM
Check the diameter of the roll pin. Maybe they put the wrong size in your kit?? I've never had one that was that difficult to install.
yeahmag |
Jan 16 2009, 12:34 PM
Advanced Member Group: Members Posts: 2,421 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
Mine was horrible to install... I only got it about 90% of the way in.
rjames |
Jan 16 2009, 01:39 PM
I'm made of metal Group: Members Posts: 3,933 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
I bent the handle on my vice trying to get that sucker installed. I ended up giving the whole thing to a buddy who works at a machine shop to have him press it in.
Find a machine shop and have them do it. It will be a quick and easy job for them and save you hours of frustration. |
914Sixer |
Jan 17 2009, 11:39 AM
I have a special tool that fits over the end of the roll pin for the installation. I will get a picture this afternoon.
veltror |
Jan 18 2009, 02:18 PM
Whoever "designed " the pedal cluster is an idiot. I spent four hours trying to get the roll pin and broke the vice. Arghhhhhhhhhh
Jan 18 2009, 02:55 PM
I'm going to guess again the roll pin is the wrong size. I've rebuilt at least a dozen pedal clusters and have yet to break my vise (IMG:style_emoticons/default/confused24.gif)
Cap'n Krusty |
Jan 18 2009, 03:02 PM
Musta been a POS (what else) Harbor freight vise. I usually use a hammer, but occasionally a vise. never a problem. As for a bolt, you'd need a barely slip fit shaft, with a minimal head and almost no threads sticking out the other side. There has to be clearance for the shaft to rotate ......... The Cap'n
Jan 18 2009, 03:39 PM
Lo-Fi Version | Time is now: 17th May 2024 - 06:32 PM |
