Special Tool for Installing Roll Pin, Pedal cluster pin |
914Sixer |
Jan 17 2009, 06:09 PM
This is a 6mm tool that holds the roll pin and squeezes it into the hole in the pedal cluster
veltror |
Jan 17 2009, 08:33 PM
Senior Member Group: Members Posts: 928 Joined: 27-April 08 From: Potters Bar Herts UK Member No.: 8,978 Region Association: None |
I recently asked a question on how to get the bloody roll pin into the bloody pedal cluster cos it bloody well was not going in. What is this tool in the picture?
Roman |
914Sixer |
Jan 18 2009, 09:04 AM
You take a pair of pliers and squeeze the roll pin into the barrel of shaft. I keeps the pin squeezed. I coat the pin with antisieze and drive it home.
ArtechnikA |
Jan 18 2009, 09:33 AM
This is a 6mm tool that holds the roll pin and squeezes it into the hole in the pedal cluster Cool. I hate that job. Where do you get that tool? I was able to do the last one in the shop but it wasn't pleasant, and I can't imagine trying to do it away from home. I'd gladly tape one of my spare roll pins to that tool & toss them both into the road-trip toolbox... |
Porsche Rescue |
Jan 18 2009, 10:51 AM
I have had good results using a vise as a press. Start the pin with a few hammer taps, then go to the vise. Also remove it using the vise, deep socket to catch the pin on one side and a short bolt slightly slimmer than the pin on the other....presto.
veltror |
Jan 18 2009, 02:21 PM
I have had good results using a vise as a press. Start the pin with a few hammer taps, then go to the vise. Also remove it using the vise, deep socket to catch the pin on one side and a short bolt slightly slimmer than the pin on the other....presto. Well the vice broke and the roll pin just laughed at me (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif) Attached image(s) |
Porsche Rescue |
Jan 18 2009, 05:25 PM
Sorry to hear that. I have done it at least 5 times with a cheap Harbor Freight vise.
Jan 18 2009, 05:29 PM
Heat it up red hot, get a BFH and beat the crap out of it...
Rich |
Lo-Fi Version | Time is now: 18th May 2024 - 10:24 AM |
