BRAG: My best ones yet., had to share |
McMark |
Jan 19 2009, 10:03 PM
Engman sells a plate to reinforce this area. But this is a street car, so stresses will be low and extra bulk is weight not strength in this scenario.
johnnie5 |
Jan 19 2009, 10:48 PM
914 lover Group: Members Posts: 375 Joined: 14-October 08 From: San Diego, CA Member No.: 9,644 Region Association: Southern California |
Nice...I am getting ready to install one as well, I can only hope my cuts come out as clean as yours. (IMG:style_emoticons/default/aktion035.gif) Like the tack in idea as well. (IMG:style_emoticons/default/beer.gif)
Krieger |
Jan 20 2009, 10:28 AM
Advanced Member Group: Members Posts: 4,723 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
63 $ incl shipping...they sure are nice though.
mightyohm |
Jan 20 2009, 10:42 AM
Nice work, Mark!
EdwardBlume |
Jan 20 2009, 03:32 PM
Solid! Good work! (IMG:style_emoticons/default/beer.gif)
tracks914 |
Jan 21 2009, 08:51 AM
Canadian Member Group: Benefactors Posts: 2,083 Joined: 15-January 03 From: Timmins, Ontario, Canada Member No.: 153 Region Association: None |
Are the factory ones welded in place?
McMark |
Jan 21 2009, 11:49 AM
Yep, but I don't have a picture of them. They're spot welded, IIRC.
sixnotfour |
Jan 21 2009, 12:03 PM
914 Wizard Group: Members Posts: 10,433 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Mark, is that a new 914 to you ? I see it in your av. so I am wondering if your going green in 09.
charliew |
Jan 21 2009, 12:39 PM
I haven't got a sway bar yet but I would rather drill a few holes in the fenderwell and button or rosette weld the plate in. If welding around the perimeter is to weatherproof the area the bottom didn't get welded so it will still need to be sealed. I guess if the suspension is still in this might be the way to go. Thanks for showing your solution though. It does show the complications of squeezing these parts in.
Jan 21 2009, 01:11 PM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
If welding around the perimeter is to weatherproof the area No. The Swaybar puts a lot of stress on the thin sheetmetal. Without welding, the metal around the holes for the bolts will eventually rip and break. Welding the backing plate helps transferring the load to a larger area. (IMG:style_emoticons/default/bye1.gif) Andy |
zonedoubt |
Jan 21 2009, 01:19 PM
Canadian Member Group: Members Posts: 668 Joined: 14-May 03 From: Vancouver, BC Member No.: 696 Region Association: Canada |
No. The Swaybar puts a lot of stress on the thin sheetmetal. Without welding, the metal around the holes for the bolts will eventually rip and break. Welding the backing plate helps transferring the load to a larger area. (IMG:style_emoticons/default/bye1.gif) Andy That's what I thought. This is to be my first welding project on my car. (IMG:style_emoticons/default/welder.gif) |
McMark |
Jan 21 2009, 03:43 PM
QUOTE Mark, is that a new 914 to you ? Nope, it's a customer car. My ugly black 914 is currently sans-engine and partway through some hell hole work. And the Aubergine 914 is still sitting under a cover. (IMG:style_emoticons/default/rolleyes.gif) |
McMark |
Jan 31 2009, 01:42 PM
This car got a hell hole repair as well. This one was also by personal best. My favorite part is that the longitudinal top patch still retains the flange that goes up. Apparently my painting skills aren't up to par though. (IMG:style_emoticons/default/laugh.gif)
ssstikircr |
Jan 31 2009, 06:06 PM
Member Group: Members Posts: 200 Joined: 11-January 09 From: Fair Oaks, Ca Member No.: 9,920 Region Association: Northern California |
Good job now I know how to do my sway bar.
Does any one know if a 911 front bar will fit in a 914? (IMG:style_emoticons/default/idea.gif) |
echocanyons |
Jan 31 2009, 09:32 PM
Advanced Member Group: Benefactors Posts: 2,094 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California |
I am so pleased with the work that you have done on my cars Mark.
This repair is no exception, definitely worth the trip! (IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/smilie_pokal.gif) Thank you! |
johnnie5 |
Jan 31 2009, 11:48 PM
Good job now I know how to do my sway bar. Does any one know if a 911 front bar will fit in a 914? (IMG:style_emoticons/default/idea.gif) Don't 911 front bars run under the car and 914 thru body? |
McMark |
Jan 31 2009, 11:52 PM
Some 911s have under body bars, some have through body. But I'm not sure about the interchangeability with 914s.
Lo-Fi Version | Time is now: 1st June 2024 - 10:31 PM |
