Brake lines for fuel, How do you run them? |
Carlitos Way |
Jan 23 2009, 12:32 PM
I did it MY WAY Group: Members Posts: 1,337 Joined: 14-September 04 From: Simi Valley, CA Member No.: 2,757 Region Association: Southern California |
A friend of mine gave me a set of brake lines that appear to be just long enough to go through the tunnel. I intend to use these to replace the fuel lines.
I pulled my old fuel lines off, and noticed the "bend" in them. I don't want to accidentally break or pinch the flow of the brake lines. So the questions are: How do you bend the brake lines so they go in the right place? and... how do you get these suckers through the grommet from the tunnel into the fuel tank? Thanks a bunch for your help! |
dr914@autoatlanta.com |
Jan 23 2009, 12:41 PM
914 Guru Group: Members Posts: 7,869 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
tangerine racing stainless replacement fuel line kit.
A friend of mine gave me a set of brake lines that appear to be just long enough to go through the tunnel. I intend to use these to replace the fuel lines. I pulled my old fuel lines off, and noticed the "bend" in them. I don't want to accidentally break or pinch the flow of the brake lines. So the questions are: How do you bend the brake lines so they go in the right place? and... how do you get these suckers through the grommet from the tunnel into the fuel tank? Thanks a bunch for your help! |
tod914 |
Jan 23 2009, 12:42 PM
yes u can use the 60" lines. cut off the flanges on both ends. You will need to pull the rubber grommet out. It's a bear, maybe ues a couple of screw drivers to do it. You'll need some kind of lubricant to get it back in, like glisterine. Blow out the lines after you cut the flanges off.
tape up the holes so u dont get any crap in there. Mark one for your feed on both ends so you know which is which. They can cross in the tunnel. Feed them through. Get a pipe bender. Use the old brass fittings for a templet to bend the trunk lines. You will not need to bend the back. Wont be enough length anyway. You can bend them in the gas tank front trunk area once they are fed through. Then pull them out enough so u can get the gromet on the work it back into the floor board. Dat's it (IMG:style_emoticons/default/biggrin.gif) Good luck |
tod914 |
Jan 23 2009, 12:43 PM
George's reckomendation is easier (IMG:style_emoticons/default/smile.gif)
A&PGirl |
Jan 23 2009, 01:10 PM
Senior Member Group: Members Posts: 1,019 Joined: 4-January 06 From: Oklahoma Member No.: 5,367 Region Association: None |
I did essentially the same thing tod914 described. Worked liked a charm and more importantly CHEAP.
Todd Enlund |
Jan 23 2009, 01:30 PM
Resident Photoshop Guru Group: Members Posts: 3,251 Joined: 24-August 07 From: Laurelhurst (Portland), Oregon Member No.: 8,032 Region Association: Pacific Northwest |
A friend of mine gave me a set of brake lines that appear to be just long enough to go through the tunnel. I intend to use these to replace the fuel lines. Long enough... okay, but what size tubing? Most brake lines are 3/16", and that's kinda on the small side for fuel. 3/8" line has four times the flow. |
VaccaRabite |
Jan 23 2009, 01:33 PM
En Garde! Group: Admin Posts: 13,446 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
tod914 |
Jan 23 2009, 01:34 PM
Good point, 5/16th is the closest you'll get to the 7mm depending on what year you have. Oh nearly forgot, you
can use some 7mm id spliced fuel around the lines inside the tunnel so they dont rattle. |
Carlitos Way |
Jan 23 2009, 01:46 PM
I think I have 1/2" feed and 3/8" or 7/16" return. Which will make the grommet all that more difficult to accommodate.
tod914 |
Jan 23 2009, 02:18 PM
If I recall, the 60" line was less than $5.00 per length at my local autoparts store. I would get the proper size. 5/16ths and 3/8ths aka 7mm & 9mm.
http://www.pelicanparts.com/techarticles/9...e_gas_lines.htm |
andys |
Jan 23 2009, 03:52 PM
I did this on my LS1 conversion, though it only requires one feed line through the tunnel (filter/regulator is in front). I retained the flared ends and nuts. NAPA has 45 degree flare to high pressure socketless hose fittings so it worked out great for me since I'm using -6 AN socketless hose in my fuel system. Since you can't feed the flare nut through the rubber grommet up front, I simply slit it and snapped the line in place before inserting it into the bulkhead (it's a pretty stout rubber piece).
Andys |
Wilhelm |
Jan 23 2009, 04:42 PM
Member Group: Members Posts: 408 Joined: 7-September 07 From: Hooterville, OR Member No.: 8,088 Region Association: None |
If you do cut off the flares you might want to use some fine sandpaper on the metal tube ends so they aren't so slippery. This will give the rubber lines over them something to grip to so they don't blow off under pressure. A not so fun thing. Fittings are much safer.
Dr Evil |
Jan 23 2009, 05:12 PM
Send me your transmission! Group: Members Posts: 23,000 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
I have done this a few times. The lines are 5/16 and 3/8 and are about $5 each. You can get a cheap pipe cutter for $5 and a bender for $5. Remove the grommet (gas tank as well), lube it with vasoline in and out, slightly bend the ends of the tubes to match the original ends (you may not even need a bender), and reassemble. I used a tubing bended because my last setup is solid line from the tank all the way through the engine bay shelf and is bend to fit the contours perfectly. Harbor Freight has the cheapo tools you need (IMG:style_emoticons/default/smile.gif) I may have pics.
bperry |
Jan 23 2009, 05:42 PM
Lurker Group: Members Posts: 477 Joined: 16-February 04 From: Dallas, Tx Member No.: 1,661 |
There is a good technical article on this:
INSTALLING STAINLESS STEEL REPLACEMENT FUEL LINES Here is the link to the 914world technical articles: Technical Articles --- bill |
Dr Evil |
Jan 23 2009, 05:46 PM
The original way I did it was easier, but less eloquent (IMG:style_emoticons/default/smile.gif) The last time I did it I had a 90* threaded fitting at the fire wall, but it was a bitch to find the parts to do it.
PRS914-6 |
Jan 23 2009, 08:30 PM
Personally I prefer to just run one length of quality fuel line from one end to the other since it avoids all the fittings and potential leaks. I slip some heat shrink tubing over the line for abrasion protection inside the cab and I use Goodridge heat insulation on all exterior sections. If you ever want to change it it's very easy to pull out.
IronHillRestorations |
Jan 24 2009, 10:50 AM
I've used the 3/8 brake line, and I put a small flare on the ends to help keep the hose on.
I wouldn't ever try and make the stainless lines again! I got some stainless line many years ago, and getting the kit from Tangerine is much easier. |
Lo-Fi Version | Time is now: 22nd May 2024 - 08:24 PM |
