Props, again. Thanks Bleyseng !, Engine shelf a batttery tray install. |
Dave Cawdrey |
Mar 28 2003, 11:15 PM
Dumbo going poop, Daddy :) Group: Members Posts: 818 Joined: 22-January 03 From: Seattle, WA USA Member No.: 182 |
Geoff welded up the shelf and support. Check out some pics.
Thanks again, dude (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/pray.gif) |
Dave Cawdrey |
Mar 28 2003, 11:18 PM
Nuther (IMG:style_emoticons/default/flag.gif)
Dave Cawdrey |
Mar 28 2003, 11:21 PM
Before (IMG:style_emoticons/default/smash.gif) No need for the damn MPS bracket (IMG:style_emoticons/default/laugh.gif)
Mar 28 2003, 11:25 PM
Damn... Nice work, Geoff!!
--DD |
Bleyseng |
Mar 28 2003, 11:29 PM
Yep, gotta try out my new autodarkening helmet too. Worked like a champ so I could actually see for once when welding. Dave car is coming along nicely! Just a few little things like the engine isn't done...paint...tranny isn't ....
Geoff |
Dave Cawdrey |
Mar 28 2003, 11:37 PM
one day at a time, geoff, one day_at_a_time. No place to put the engine...
Tranny is ready, no exterior paint til flares... OOOhhhh John Kelly, hows that list coming? |
boxstr |
Mar 29 2003, 12:04 AM
Looks like MONSTER GARAGE......
Jeroen |
Mar 29 2003, 04:50 AM
Welding bearhanded again Geoff?
You are my hero (IMG:style_emoticons/default/biggrin.gif) Great work! cheers, Jeroen |
rhodyguy |
Mar 29 2003, 07:53 AM
dave, looks like you have some of that damn adhesive that held the sound pad on to remove. i started with 3M adesive remover. way too much elbow work, plus your face is in fumes,hazmat gloves, big mess. then a fellow owner suggested i try gumout carb and choke cleaner. i sprayed it on and let it work for a while. the adh came off like a breeze. plus a couple of cans of g.o. are much cheaper than a qrt. of the 3M. then i used one of those abrasive impregnated nylon wheels in my cordless to clean up any resid. i figured it saved me hours in that open engine compartment.
kevin |
tracks914 |
Mar 29 2003, 08:59 AM
Canadian Member Group: Benefactors Posts: 2,083 Joined: 15-January 03 From: Timmins, Ontario, Canada Member No.: 153 Region Association: None |
I noticed in the rear fender behind the battery tray, you don't have the two holes that I have. Are mine supposed to be there? When I saw them on mine, I thought they would spray water and mud up into the engine compartment. I don't remember anything going through them whenI stripped down the car.
rhodyguy |
Mar 29 2003, 09:10 AM
does your front trunk floor have a big sq hole in it? if so those could have been for a/c hoses.
Dave Cawdrey |
Mar 29 2003, 01:16 PM
QUOTE(rhodyguy @ Mar 29 2003, 05:53 AM) dave, looks like you have some of that damn adhesive that held the sound pad on to remove. i started with 3M adesive remover. way too much elbow work, plus your face is in fumes,hazmat gloves, big mess. then a fellow owner suggested i try gumout carb and choke cleaner. i sprayed it on and let it work for a while. the adh came off like a breeze. plus a couple of cans of g.o. are much cheaper than a qrt. of the 3M. then i used one of those abrasive impregnated nylon wheels in my cordless to clean up any resid. i figured it saved me hours in that open engine compartment. kevin I think the aircraft stripper will get it good. I'm looking to get to that bare metal stuff. Either stripper or blast, haven't decided whats more messy (IMG:style_emoticons/default/confused24.gif) |
tracks914 |
Mar 29 2003, 04:46 PM
QUOTE(rhodyguy @ Mar 29 2003, 07:10 AM) does your front trunk floor have a big sq hole in it? if so those could have been for a/c hoses. My trunk had two big square holes cut in the bottom. I cut out the whole bottom and replaced it with another one. No sign of A/C though. |
Bleyseng |
Mar 29 2003, 05:00 PM
I had to replace the front trunk floor (see earlier thread) as the PO had cut a hole with a torch to open the front trunk due to a broken cable. Real smart...
Geoff |
Aaron Cox |
Mar 29 2003, 10:30 PM
dunt ja love previous owners! mine drilled holes for race harnesses in the floor pans- and left them there. also drilled through backpad and firewall. hey what can i say? i didnt own the car at the time- i just live with it- also have carpet just floating around in the cockpit.(IMG:style_emoticons/default/mad.gif) my car doesnt have those holes either- but on that piece i mounted my carb. fuel pressure regulator. looks totally sano. worked out fine.
Brad Roberts |
Mar 30 2003, 12:31 PM
Good job Ge-off.
Did you guy's drill the two holes for the fuel pump mounts prior to the install ?? B |
Dave Cawdrey |
Mar 30 2003, 03:27 PM
QUOTE(Brad Roberts @ Mar 30 2003, 10:31 AM) Good job Ge-off. Did you guy's drill the two holes for the fuel pump mounts prior to the install ?? B No, but Im going to carbs. Prolly gonna mount the rotory some place on top of the shelf... |
Aaron Cox |
Mar 30 2003, 04:57 PM
QUOTE(Jeroen @ Mar 29 2003, 02:50 AM) either bearhanded or BEER HANDED - the only way to go... nicce welding (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beerchug.gif) |
Bleyseng |
Mar 30 2003, 06:32 PM
Yeah, Dave stiffed me again for a beer. Hell, there is a pub upstairs from the garage we were working in. But nooo, can't buy me a beer soo next time is going to cost him big time.
Geoff |
Dave Cawdrey |
Mar 30 2003, 07:31 PM
QUOTE(Bleyseng @ Mar 30 2003, 04:32 PM) Yeah, Dave stiffed me again for a beer. Hell, there is a pub upstairs from the garage we were working in. But nooo, can't buy me a beer soo next time is going to cost him big time. Geoff No fun in buying you a beer when I cant drink :finger2: (IMG:style_emoticons/default/tongue.gif) Got some wine and coffee comin fer ya. The MIL sabotaged the damn kitchen (IMG:style_emoticons/default/ar15.gif) (IMG:style_emoticons/default/fighting19.gif) |
Lo-Fi Version | Time is now: 20th May 2024 - 04:30 AM |
