OIL LINES?, Has any one used pipe to run lines? |
jeff |
Feb 19 2004, 07:48 PM
Member Group: Members Posts: 252 Joined: 17-January 04 From: thousand oaks,ca Member No.: 1,570 |
Has anyone used stailess pipe behind the rockers with short AN (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/sawzall-smiley.gif) style hoses?There is less friction in a solid pipe vs a flexable hose and the hose is alot more expensive if you have to run the whole length of the car. I would like to run my cooler and dry sump tank in the front ,if anybody has input i would appreciate it.How do you get pictures on the board I have a digital cam but limited brain on the computer oh those litte faces too any help would be great
TimT |
Feb 19 2004, 07:59 PM
Welcome to the club!!!
Ive used aluminum pipe with -12 -16 or -20 ends welded on through the tub on 911's My 914 came complete with -12 run through the rockers... actually you dont save to much dinero when you run lengths of pipe.. you have to buy more AN fittings... which cost more than a few feet of hose... six of one half dozen of the other... BTW on the 911's using large diameter pipe is really just increasing the capacity of the oiling system. |
TimT |
Feb 19 2004, 08:00 PM
oh I think you can post pics after your 10th post
Lo-Fi Version | Time is now: 18th May 2024 - 01:15 PM |
