Early door reasembly help needed |
ahdoman |
Feb 4 2009, 10:55 PM
It's phonetic...Ah-D-O-Man (Audioman) Group: Members Posts: 667 Joined: 7-November 05 From: Santa Clarita, Ca. Member No.: 5,084 Region Association: Southern California |
I've got the Haynes manual and I took the doors apart so I sort of know how to do this. But, can anybody give me a rough proceedure of door reassembly (i.e. - start with reattaching door lock, then install window lifter, etc.). Just the basic assembly steps is all I'm looking for; what goes in when.
ericread |
Feb 4 2009, 11:10 PM
The Viper Blue 914 Group: Members Posts: 2,177 Joined: 7-December 07 From: Irvine, CA (The OC) Member No.: 8,432 Region Association: Southern California |
I've got the Haynes manual and I took the doors apart so I sort of know how to do this. But, can anybody give me a rough proceedure of door reassembly (i.e. - start with reattaching door lock, then install window lifter, etc.). Just the basic assembly steps is all I'm looking for; what goes in when. Try this link: http://www.914world.com/bbs2/index.php?sho...c=12454&hl= Eric |
ahdoman |
Feb 4 2009, 11:23 PM
Thanks Eric but that is for a late door and the lock rebuild. I'm looking to put an early door back together. Locks and handles are lubed and ready. I did the search and came up empty that's why I'm asking.
2-OH! |
Feb 5 2009, 02:21 PM
Senior Member Group: Members Posts: 552 Joined: 17-October 03 From: Santa Clarita, Kalifornication Member No.: 1,253 |
Mount door on car
Door Handle mechansim & lock Tracks for window and fake vent window Winder mechanism (after cleaning and heavy lube using 30wt oil) At this step, only use Brad Penn...It's the only oil of choice... Window glass (do not attach until after next step) Rails for seals at top slot in door...Install fuzzy first, then install on car (good luck) Lubicate squeege seal heavily with vinyl dressing and slide into track Attach glass to winder mech..Operate ad Nauseum until working good... Rail for door latch to inside handle...Be sure to insulate or it will rattle against door Dynamat (or similar) instead of plastic for mositure barrier Door panel Handles & storage armrest By the way, some people have been known to line in outer skin of the door with dynamat (or similar) to help keep the noise down...Yea it adds a little weight, but makes it much quieter...And besides with that giant six, ten pounds on a daily driver is nothing... |
ericread |
Feb 5 2009, 04:25 PM
Thanks Eric but that is for a late door and the lock rebuild. I'm looking to put an early door back together. Locks and handles are lubed and ready. I did the search and came up empty that's why I'm asking. Sorry (IMG:style_emoticons/default/confused24.gif) Just a thought... Eric |
Lo-Fi Version | Time is now: 9th June 2024 - 03:24 PM |
