FS: ready to run 930 w lsd, pretty much everything you need |
pffft |
Feb 6 2009, 12:59 PM
Member Group: Members Posts: 189 Joined: 18-January 05 From: sierra foothills Member No.: 3,465 |
Change in plans leads me to offer this
(I also have a new (never started) sbc w/ afr heads and complete Renegade system that could be included in a package deal.) 1987 930 box pulled from turbo with 40K miles Bellhousing shortened and ring and pinon flipped by Bobby Hart All new syncros All new dog teeth New sliders/selectors New Bearings All under 1000 miles New Quaiffe Limited Slip (under 500miles) Running Swepco 201 oil All work performed by Allan Faragalah at Aase Motorsport Pair of 930 halfshaft/axles w/cv's Kennedy 930 V8 flywheel w/ 930 starter ring gear Modified 930 Clutch, balanced to Kennedy Flywheel Stock 930 disk (new) 930 throw out bearing Cable shifter complete High Torque starter custom 914 clutch cable bracket and pully and the custom tranny bracket to mount to the stock tranny location. All under 1000 miles $7100 Located in foothills between Sacramento and Lake Tahoe |
Lo-Fi Version | Time is now: 19th May 2024 - 02:52 PM |
