type 4 screws not loose |
dflesburg |
Feb 9 2009, 06:46 PM
Senior Member Group: Members Posts: 1,720 Joined: 6-April 04 From: Warm and Cheerful Centerville Ohio Member No.: 1,896 Region Association: None |
have a type 4
cant get screws holding tin on to turn. Dont want to bugger them up.. anyone had this problem? What did you do? |
JoeSharp |
Feb 9 2009, 07:29 PM
In Irvine, Ca. May 15-18 Group: Members Posts: 3,947 Joined: 9-July 03 From: DeLand, Florida Member No.: 898 Region Association: South East States |
Sometimes it takes an impactdriver. I will also use a large screwdriver with a square shaft and turn it with a wrench. The secret is keeping the screwdriver seated.
ssstikircr |
Feb 9 2009, 07:39 PM
Member Group: Members Posts: 200 Joined: 11-January 09 From: Fair Oaks, Ca Member No.: 9,920 Region Association: Northern California |
Try somekind of a penatrating lube. You can also try using heat like from a mini propane torch. You will be surprised how heat can actually help.
Cevan |
Feb 9 2009, 07:42 PM
Senior Member Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 |
Use heat. I also use an old screwdriver that has a square shaft that I can put an 8mm wrench on. I also have filed the tip to perfectly match the cheesehead screws. I've removed 4 sets of tins that way.
MDG |
Feb 9 2009, 07:58 PM
Wolf in wolf's clothing. Group: Members Posts: 8,652 Joined: 3-February 09 From: Toronto Member No.: 10,018 Region Association: None |
+1
just went through the same thing and it was a pain; I shot some PB on and let it soak; applied a little heat and they came off no problems. As Joe said, make sure you keep the head of your driver seated flat; if it rocks around to much the screws come apart. good luck m. |
Gint |
Feb 9 2009, 08:57 PM
Mike Ginter Group: Admin Posts: 16,075 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Sometimes it takes an impactdriver. I will also use a large screwdriver with a square shaft and turn it with a wrench. The secret is keeping the screwdriver seated. (IMG:style_emoticons/default/agree.gif) Impact screw driver works GREAT for removing stubborn tin screws. One tap of the hammer on the driver and the screw is turning out. From there it comes right out with a standard screw driver. |
ericread |
The Viper Blue 914 Group: Members Posts: 2,177 Joined: 7-December 07 From: Irvine, CA (The OC) Member No.: 8,432 Region Association: Southern California |
Let's see now. You have a 914 and you have a screw loose...
Seems redundant to me... (IMG:style_emoticons/default/lol3.gif) |
Feb 9 2009, 09:06 PM
I found that the biggest screwdriver that Sears sells was the only thing that actually fit the engine tin screws. Using the correct-sized screwdriver helped a lot, as did spraying them with penetrating oil.
Access for a screwdriver that large is just about nonexistent for some of the screws, sad to say. I had the engine out when I was removing them. --DD |
Feb 9 2009, 09:20 PM
Custom Member Group: Members Posts: 24,576 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Impact screw driver...the only way to go.
Use PB Blaster Rich |
Lo-Fi Version | Time is now: 20th May 2024 - 04:27 PM |
