Welders and metal guys, Need your advice |
PeeGreen 914 |
Feb 11 2009, 06:56 PM
Just when you think you're done...wait, there is more..lol Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest |
Any pics of what you're talking about JP? Thanks for the advice. I know better with POR. I used zero rust on the interior and it was amazing.
J P Stein |
Feb 11 2009, 08:01 PM
Not any real good pics, but.......a few accidental views.....enuff to give you the general idea.
Attached thumbnail(s) |
charliew |
Feb 11 2009, 10:40 PM
If you have room I would do the brace straight forward to the firewall area as that would give more support and wrap a piece around the ear to fasten it to.
Gint |
Feb 12 2009, 07:53 AM
Mike Ginter Group: Admin Posts: 16,082 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
If you have room I would do the brace straight forward to the firewall area as that would give more support and wrap a piece around the ear to fasten it to. You want to measure carefully before doing that. You don't want to find out you can't get your engine back in the car afterwards. (IMG:style_emoticons/default/wink.gif) |
degreeoff |
Feb 12 2009, 08:11 AM
I like big butts and I can not lie! Group: Members Posts: 1,622 Joined: 9-February 03 From: Booowieeee MD (near DC) Member No.: 275 Region Association: MidAtlantic Region |
Hey Jon...here is what I did and I believe its where JP is talking about? Sorry for the poor pics but I have misplaced the ones while in progress..... (IMG:style_emoticons/default/dry.gif)
PeeGreen 914 |
Feb 12 2009, 10:21 AM
If you have room I would do the brace straight forward to the firewall area as that would give more support and wrap a piece around the ear to fasten it to. You want to measure carefully before doing that. You don't want to find out you can't get your engine back in the car afterwards. (IMG:style_emoticons/default/wink.gif) Why would that be a problem? (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/laugh.gif) Thanks Josh, I can understand that now. I can see on my car where that would help. |
Bleyseng |
Feb 12 2009, 11:31 AM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
I think those brace mods will toss you outta of GTU class, suspension mods are limited to machining not welding in braces...you can weld up the ear like JP says..
PeeGreen 914 |
Feb 12 2009, 11:39 AM
Not in GTU anymore. I'm in MU now. I get to race against Greg Fordahl and a bunch of other ITS 944s (IMG:style_emoticons/default/piratenanner.gif)
rjames |
Feb 12 2009, 02:19 PM
I'm made of metal Group: Members Posts: 3,948 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
QUOTE BTW, don't get near that rust with Por-15......Rust Mort or Ospho with a coat or 2 of etching primer will see you thru ....till next time. A lot of folks are down on Por-15, but if used correctly and as directed, I think it works great. I think a lot of people make the mistake of not treating the rust before applying it. Por-15 is not a rust converter, it's a sealer/primer. The product the company makes for rust converting is MetalReady which is a converter/metal etching solution. Just my $.02, now back to the original thread already in progress. (IMG:style_emoticons/default/biggrin.gif) |
PeeGreen 914 |
Feb 12 2009, 03:44 PM
I will have to disagree. The PO did my car properly and there were areas under the POR that still had rust when I redid the floor. Also, the guy that was helping me with my interior showed me a ton of pictures of cars that people used POR on and they were all done correctly by a top notch shop. He showed me a few different products and why he only uses Zero Rust.
charliew |
Feb 12 2009, 11:43 PM
When you use the metal ready it turns the rust black. Who's to know if it turns the rust black all the way down to good steel. The best way will always be to remove all the rust and use a good epoxy primer to seal it, nothing seals better than epoxy primer over good clean steel. I have used lots of por 15 but it is mainly to seal the rust and maybe it will keep it from starting up again. My biggest concern is getting other paints and undercoat to stay on top of it. It is a very hard slick finish. if you try to sand it or scuff it and go through what good is the sealer part of the application. On non sanding epoxy primer you can just shoot the type of top coat over the primer and it sticks great and won't ever lift. I haven't had that result every time with por15. I do know acids won't touch por15 and it is really tough stuff if you apply it perfectly.
I usually use por15 on stuff that isn't cosmetically perfect but that I want a tough surface on. It will turn some ugly colors out in the sun so it will need to be top coated if exposed to sunlight. Restomotive sells a tiecoat primer that works good over por15 but that is another paint you will need in the budget. It is a baby blue colored primer. |
thesey914 |
Feb 13 2009, 04:12 AM
Senior Member Group: Benefactors Posts: 1,155 Joined: 1-January 03 From: Staffordshire -England Member No.: 66 |
I had similar rust under my 4 cyl mount but I had a hole underneath> I ended up putting another small patch to cover the little 'kidney bowl' too.
I cut out all the rust as there is the inner heavy-gauge ribbed piece below. Then welded a new skin over the top. |
thesey914 |
Feb 13 2009, 07:29 AM
This is the hole I found but the metal underneath was sound. Excuse the welding I was working with my new Miller and was still experimenting with settings -it all ground back flush (IMG:style_emoticons/default/smile.gif)
(IMG:http://www.thesey.com/pictures/4mount%20.jpg) (IMG:http://www.thesey.com/pictures/4mount2%20.jpg) (IMG:http://www.thesey.com/pictures/4mount3%20.jpg) |
Richard Casto |
Feb 13 2009, 08:36 AM
QUOTE BTW, don't get near that rust with Por-15......Rust Mort or Ospho with a coat or 2 of etching primer will see you thru ....till next time. A lot of folks are down on Por-15, but if used correctly and as directed, I think it works great. I think a lot of people make the mistake of not treating the rust before applying it. Por-15 is not a rust converter, it's a sealer/primer. The product the company makes for rust converting is MetalReady which is a converter/metal etching solution. Just my $.02, now back to the original thread already in progress. (IMG:style_emoticons/default/biggrin.gif) I agree. I think people expect it to work magic. I think a common problem is lack of cleaning of oil, etc. The other is that they treat metal that is rusted through and they coat just one surface, so it rusts from the inside out. I have no doubt that "professionals" can screw it up as well. I also am a big fan of media blasting vs. rust conversion only for two reasons. (1), why convert rust to something else (and probably not get it all) when you can remove it. (2), it creates a "surface profile" that gives whatever you choose (POR or something else) something to adhere to properly. Also, I think the something like Ospho works much better after a very light media blasting. Try this yourself if you have some Ospho or Metal Ready. Take some new sheet metal. Cut it into three sections. Clean all three (remove oil, etc.). Leave one as is, clean one with a flapper disk on a grinder or use a knotted wire wheel on it, lightly media blast the last one. Then spray all three with Ospho/Metal Ready. You will see that the first two don’t get etched much at all. In fact I think the second one that was sanded, ends up with a polished surface that doesn’t get etched much at all. The last one is etched much more than the other two. Which one do you think will work best with a sealer/primer like POR or some other product? My 2 cents as well. Sorry for the hijack. (IMG:style_emoticons/default/beerchug.gif) |
Richard Casto |
Feb 13 2009, 08:49 AM
My biggest concern is getting other paints and undercoat to stay on top of it. It is a very hard slick finish. if you try to sand it or scuff it and go through what good is the sealer part of the application. I think that is a good point. I think that is why an epoxy primer is the right thing for 99% of the car. But POR 15 is good if you need to get at areas you can’t spray into. Two examples of this. First is if you are working on an area that you will be covering up (such as multiple layers of metal). I would use POR 15 or a good weldable primer or maybe both in that situation. An example of this for me is my replacement passenger suspension console. I used POR15 on the majority of the interior prior to welding it to the car as well as weldable primer on the areas that would be welded. This was on brand new un-rusted metal. I guess if you want to get out your spray gun and set it up for something that small, then use the epoxy primer, but I think that POR 15 beats it due to convenience in that situation. The second is to use POR 15 to flow via capillary action into seams. That an area that you can’t reach with a spray on primer or with seam sealer. |
Richard Casto |
Feb 13 2009, 09:03 AM
Crap, I hate replying to my own posts. (IMG:style_emoticons/default/sad.gif)
I re-read my posts above, and I am not knocking Zero Rust. I think lack of proper prep work or using it on parts that are overly rusted to begin with will cause both POR 15 and Zero Rust to fail. |
Lo-Fi Version | Time is now: 31st May 2024 - 05:18 PM |
