1974 914 2.4==SOLD=, Set Up fot Auto X or DE |
tody copeland |
Feb 11 2009, 12:57 PM
Newbie Group: Members Posts: 3 Joined: 4-July 08 From: Ruidoso,New Mexico Member No.: 9,247 Region Association: Southwest Region |
==SOLD==Fresh 2.4= 71mm X104mm with twin webber 44IDF,Keith Black pistons, polished Nitride Fat crank 71mm, Mid ported heads, Kolbo Schmith Main bearings, Fat mild Cam, Oil cooler with fan, S.S. oil lines, Turbo Tie rds, Solid front motor mounts, JOS Trans. gears, MSD-6L, Bilstien sport ft. shocks, Gear reduction starter, Kerry Hunter headers, Brakes Ft. BMW 321-I, Ft. & Rr drilled rotors, S.S. Lines, 180 lb. rear springs, Dos roll bar, Driver 5 point harness, Rennline alum. petals, 9.8 compression, 4 reviera wheels with Yokahama tires, 4 Padrinne with Kumho Victotrace 205/50/15 tires, battery moved to rear trunk, Paint app. 2 years old Seal Gray 2001 Porsche, Lightened flywheel, Very little rust , Car is very fast and goes where you point it. Can email as may photos as you like. $7500.00
tody@bajabb.com |
Millerwelds |
Feb 11 2009, 01:02 PM
Pleepleus Group: Members Posts: 715 Joined: 24-June 08 From: Grass Valley, CA Member No.: 9,206 Region Association: Northern California |
Price?
sam quartermain |
Feb 11 2009, 04:45 PM
The desire for glory is not a sin, TY COBB Group: Members Posts: 58 Joined: 2-February 09 From: monrovaia ca/ tarzana ca Member No.: 10,011 Region Association: None |
So would this car be suitable for a daily driver ?/ and how intrusive is the roll barring |
Lo-Fi Version | Time is now: 17th May 2024 - 08:40 PM |
