Click to view attachmentClick to view attachmentClick to view attachment ==SOLD==Fresh 2.4= 71mm X104mm with twin webber 44IDF,Keith Black pistons, polished Nitride Fat crank 71mm, Mid ported heads, Kolbo Schmith Main bearings, Fat mild Cam, Oil cooler with fan, S.S. oil lines, Turbo Tie rds, Solid front motor mounts, JOS Trans. gears, MSD-6L, Bilstien sport ft. shocks, Gear reduction starter, Kerry Hunter headers, Brakes Ft. BMW 321-I, Ft. & Rr drilled rotors, S.S. Lines, 180 lb. rear springs, Dos roll bar, Driver 5 point harness, Rennline alum. petals, 9.8 compression, 4 reviera wheels with Yokahama tires, 4 Padrinne with Kumho Victotrace 205/50/15 tires, battery moved to rear trunk, Paint app. 2 years old Seal Gray 2001 Porsche, Lightened flywheel, Very little rust , Car is very fast and goes where you point it. Can email as may photos as you like. $7500.00
tody@bajabb.com
