Right Front locking up before everything else, I need a few ideas to troubleshoot |
DNHunt |
Feb 11 2009, 04:54 PM
These are new to me front struts with vented rotors and M calipers I think. Anyway there are only about a hundred miles on them I think. I'm not giving you much info I know but, any ideas will help.
Dave |
turboman808 |
Feb 11 2009, 05:00 PM
Advanced Member Group: Members Posts: 2,718 Joined: 31-January 06 From: North Jersey Member No.: 5,505 Region Association: North East States |
These are new to me front struts with vented rotors and M calipers I think. Anyway there are only about a hundred miles on them I think. I'm not giving you much info I know but, any ideas will help. Dave I had the same problem on another car and it turned out the other front brake had air in the line. |
melnyk |
Feb 11 2009, 05:15 PM
Member Group: Members Posts: 104 Joined: 26-July 08 From: wilkes-barre Member No.: 9,359 Region Association: None |
Eric_Shea |
Feb 11 2009, 05:29 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Sticking piston?
Bad rubber line? If there's air in the system the pedal will be spongy. |
Joe Ricard |
Feb 11 2009, 05:38 PM
Spring rates, corner wieght bias Good shocks as in no skipping spots in it range of motion.
J P Stein |
Feb 11 2009, 05:46 PM
I have found that a few 1/16 dia air bubbles will cause this with no softness of the pedal....but it pulls that way first. My S calipers are a bitch to bleed properly.
It's been known to take 2-3 runs at it with a couple days between bleedings. |
DNHunt |
Mar 1 2009, 04:59 PM
Well, it turned out to be bad seals. The caliper was leaking around the pistons.
DNHunt |
Mar 1 2009, 05:01 PM
Replaced the seals and dust boots and cleaned things up. Re-bled the brakes and I'll try it when the 40 day flood stops.
messix |
Mar 1 2009, 05:08 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
um ya that'll be about july 5th
KELTY360 |
Mar 1 2009, 05:13 PM
914 Neferati Group: Members Posts: 5,035 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest |
Does this mean the engine is all back together and you're just about ready to be on the road again?
DNHunt |
Mar 2 2009, 08:24 AM
Does this mean the engine is all back together and you're just about ready to be on the road again? Yep, I've been driving it near home for a while, terrorizing highway 16 and generally pissing off people. I'm ticking off the things on my check list. Oil leakes have been a bitc( to fix but, I think I have it dry now. I'm getting it aligned and cornerbalanced Wednesday, tires Thursday. If the brakes are cured I'll be up for longer drives. The goal is about 1500 miles before WCR. Dave |
6freak |
Mar 2 2009, 08:38 AM
Does this mean the engine is all back together and you're just about ready to be on the road again? Yep, I've been driving it near home for a while, terrorizing highway 16 and generally pissing off people. I'm ticking off the things on my check list. Oil leakes have been a bitc( to fix but, I think I have it dry now. I'm getting it aligned and cornerbalanced Wednesday, tires Thursday. If the brakes are cured I'll be up for longer drives. The goal is about 1500 miles before WCR. Dave Nice work Dave! (IMG:style_emoticons/default/smilie_pokal.gif) |
KELTY360 |
Mar 2 2009, 09:45 AM
Does this mean the engine is all back together and you're just about ready to be on the road again? Yep, I've been driving it near home for a while, terrorizing highway 16 and generally pissing off people. I'm ticking off the things on my check list. Oil leakes have been a bitc( to fix but, I think I have it dry now. I'm getting it aligned and cornerbalanced Wednesday, tires Thursday. If the brakes are cured I'll be up for longer drives. The goal is about 1500 miles before WCR. Dave Nice work Dave! (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/agree.gif) |
DNHunt |
Mar 8 2009, 08:12 AM
After I got the caliper rebuilt, I still had a bit of a leak from the hard line into the caliper. I replaced the hard line and now all is good. The car stops straight.
My punch list is getting shorter. I have some gas fumes in the car, so I need to check the lines from the tank to the hard lines. It also could be from cutting the line to the charcoal cannister (charcoal cannister went bye bye). Also, I can't get enough fuel to tune WOT so I suspect that my fuel filter is clogged. I suppose it could be related to the fuel smell too. Anyway, for a couple of days I'll be driving a creeper instead of a teener. When I get those two items, it's just put miles on it before the trip to LaLa and WCR. Yahoo! Dave |
Gary |
Mar 8 2009, 08:31 AM
Senior Member Group: Members Posts: 744 Joined: 12-January 03 From: Mount Airy, MD Member No.: 134 Region Association: MidAtlantic Region |
Great to see Dave. Looks like you're getting close.
rhodyguy |
Mar 8 2009, 12:43 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,085 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
when was the last time you inspected the strainer sock in the tank? as clean as mike's(6freak) tank was, his strainer was smooshed flat and grossly dirty. i bet he picks up 15 hp with a clean one.
k |
ConeDodger |
Mar 8 2009, 01:02 PM
Apex killer! Group: Members Posts: 23,607 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
These are new to me front struts with vented rotors and M calipers I think. Anyway there are only about a hundred miles on them I think. I'm not giving you much info I know but, any ideas will help. Dave See a dentist and have your bite checked (IMG:style_emoticons/default/lol-2.gif) Sorry... I know, I'm an asshat... |
Tom |
Mar 10 2009, 10:52 AM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
Dave,
Good to hear you have it back on the road. Hope to catch up to you some time at Bremerton this spring or summer. Tom |
dinomium |
Mar 10 2009, 06:36 PM
Git on a chair son, all the good stuff is goin over yer head! Group: Benefactors Posts: 2,777 Joined: 2-January 03 From: Bremerton, WA Member No.: 74 Region Association: Pacific Northwest |
hey, Dave did you put in those strut bearings you got from me at Walkers? Just curious...
Lo-Fi Version | Time is now: 3rd June 2024 - 06:49 PM |
