early doors vs. late doors differences, Need Assembly help! |
ahdoman |
Feb 13 2009, 09:59 PM
It's phonetic...Ah-D-O-Man (Audioman) Group: Members Posts: 667 Joined: 7-November 05 From: Santa Clarita, Ca. Member No.: 5,084 Region Association: Southern California |
Ok, here's the deal...I am in the process of putting my 1970 back together. In my pile of spare parts I have 2 sets of the front rail (part #15) for the window. One set is from late doors and another from early doors. I know this for a fact because I took both of them apart. But, I neglected to keep them seperated. Anybody know which is early vs. late. They seem to be different; One pair is slightly longer (by about 1/2") and the radius is a little greater. Other than that I can't tell the difference.
Also, Is there any kind of weatherstrip that goes in the early track? I don't see how it would work with the rollers (part #6). |
Feb 13 2009, 10:50 PM
No weatherstripping in mine.
Take the longer of the two, stick in in the door and see of the bolts line up with the holes in the door...simple easy way to check. Line up the bolts and the front window glass notch. Rich |
ahdoman |
Feb 13 2009, 11:06 PM
Thanks for the suggestion Rich. It was a good idea but unfortunately the bolt holes line up on both sets.
Just thinking...has anybody ever cut the axles off of the guide rollers and used the weatherstrip? Kind of a "hybrid" design between early and late? I'm affraid to try it because I'm affraid the window will want to pivot on the point where it's tied to the lifter and it will end up binding in the channel. |
Feb 13 2009, 11:13 PM
The bolts holes line up...top and bottom?
Does the front notch on the little triangle window line up with the door skin top? If so, you might need to put the door on the car...geez...I thought the slides had different upper mounting bolts...mine do. You need the rollers if you are using the cable guide from the early door. You can retro fit the later style scizzor setup for the window into the early door...but it requires some metal fabrication work on the door. The benefit...you get weather stripping. Rich |
ahdoman |
Feb 13 2009, 11:21 PM
Too late to do any metal fabrication...besides I prefer the weight loss! It's amazing how much lighter the early doors are.
SLITS |
Feb 14 2009, 09:30 AM
The difference is in the way the channel is formed, but I don't remember which way. Narrow gap for window = early, wide gap for window w/felt = late (I think)
PRS914-6 |
Feb 14 2009, 11:20 AM
You can rob the equipment and windows out of the new style and use them in the old style doors. It takes a little work but I did mine after paint with no ill effects. It takes a little bending, cutting and welding but it's a nice modification to end the cheesiness and rattles of the early style and you save a BUNCH of weight at the expense of some personal safety.
Wide channel=late Narrow=early There are several threads on how to do the mod but here are a few pics of what is involved: |
Gint |
Mike Ginter Group: Admin Posts: 16,071 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
(IMG:style_emoticons/default/agree.gif) with the ole fart.
Got a pair of /6 doors with the window mechanisms still intact in the shed. I can take pics of the rails if it will help. I'll be in and out the rest of the day. PM or email me if you need it quick. |
McMark |
Feb 14 2009, 11:15 PM
Early has a narrow opening and no weatherstrip, late has a large opening to take the rubber/felt.
Lo-Fi Version | Time is now: 16th May 2024 - 03:06 PM |
