| rhodyguy |
Feb 15 2009, 04:53 PM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,254 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
nice score.
you should have known better craig. what are ya? NEW!!? i'll be surpised if the other parts will be avail. k |
| Eric_Shea |
Feb 15 2009, 05:05 PM
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Something on those stub axles doesn't look factory. The nubs to be more specific. I could be wrong...
| sixnotfour |
Feb 15 2009, 05:52 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,397 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
could they be 108 ?
this more interesting than the Dationa 500 |
| zig-n-zag |
Feb 15 2009, 06:56 PM
Member ![]() ![]() Group: Members Posts: 220 Joined: 18-May 06 From: Hawaii Member No.: 6,024 |
The mittlemotor stubs I sold, seemed to have a thicker flange where it
mates with the cv joint, that was my impression of them. They also could be 911 pieces added to the trailing arms, if not real /6. Well bought! |
| MrKona |
Feb 15 2009, 09:07 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 597 Joined: 25-July 05 From: Santa Rosa, CA Member No.: 4,469 Region Association: None |
Something on those stub axles doesn't look factory. The nubs to be more specific. I could be wrong... Perhaps this solves one of the greatest Porsche mysteries ever... what really happened to the special pair of prototype stub axles meant for Ferdinand Porsche's 914-8. 38 years later, it is a mystery no more... There are no markings on them. I haven't yet taken them off the CVs, won't be able to do that until next weekend. I'm using a picture of 914/6 stubs from Pelican parts (attached) for comparison. Attached thumbnail(s) Attached image(s)
| Eric_Shea |
Feb 15 2009, 10:41 PM
Here's a picture Andy posted in Reid's thread:
(IMG:http://www.914world.com/bbs2/uploads/post-179-1232575175_thumb.jpg) Looks like they could be the real deal. |
| JRust |
Feb 16 2009, 12:34 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,317 Joined: 10-January 03 From: Albany Oregon Member No.: 129 Region Association: Pacific Northwest
Excellent! Nice find Bryan (IMG:style_emoticons/default/piratenanner.gif)
I wonder on the set as I bought & sold a 75 I think years ago. It had a complete 5-lug setup on it. I wonder if you could special order one that way. The car was pretty unimpressive besides. I wouldn't have thought someone made the swap (IMG:style_emoticons/default/confused24.gif) . I know the car made the rounds as I sold it to Craig who later sold it to someone up in Portland. Guy told me they were real 6 rears on it? Car was a 75 though? One o fthe cars I sold I should have hung onto (IMG:style_emoticons/default/headbang.gif) |
| Eric_Shea |
Feb 16 2009, 09:57 AM
QUOTE I wonder if you could special order one that way. Not that I know of. |
| Lavanaut |
Feb 16 2009, 12:35 PM
Hungry Mind : Thirsty Gullet ![]() ![]() ![]() Group: Members Posts: 916 Joined: 20-June 06 From: Bend, OR Member No.: 6,265 Region Association: Pacific Northwest |
I tapped the stub axle and out came.... what I believe is a 914/6 stub axle! 28 splines, sure looks like one, but I've only seen them in pictures! Can anyone confirm? 28 splines, yep, you're golden! Nice find. Looks like those things have taken some abuse, I wonder if this is cause for concern? "I" wonder, others here will just know. (IMG:style_emoticons/default/biggrin.gif) |
| MrKona |
Feb 21 2009, 12:18 AM
I tapped the stub axle and out came.... what I believe is a 914/6 stub axle! 28 splines, sure looks like one, but I've only seen them in pictures! Can anyone confirm? 28 splines, yep, you're golden! Nice find. Looks like those things have taken some abuse, I wonder if this is cause for concern? "I" wonder, others here will just know. (IMG:style_emoticons/default/biggrin.gif) I don't think so... the grooves are equal on both stubs and and look like they're "supposed" to be there. Strange though, as they are absent in the pictures of other 914/6 stubs... I noticed that too... (IMG:style_emoticons/default/confused24.gif) |
| MrKona |
Feb 21 2009, 12:22 AM
I've begun to disassemble the rear trailing arms. I drove out the hubs with a metal pipe and hammer, and then removed the stubs from the CVs. I had to figure out how to hold the axles to loosen the CV bolts with the axles removed from the car. I ended up bolting the already removed hubs to the disks, then clamping the disks in a vice, then fitting the stub inside the hub, which worked just fine.
All I can say is what a dirty, greasy, disgusting mess this is. Attached thumbnail(s) |
| MrKona |
Feb 21 2009, 12:24 AM
Tonight I removed the bearings from the trailing arms. In order to do this atraumatically, I made a homemade bearing puller for about $10 and a trip to Ace Hardware.
| MrKona |
Feb 21 2009, 12:26 AM
Bearing cap and removal... Did I mention what a dirty mess this is?
| MrKona |
Feb 21 2009, 12:27 AM
Bearing cap removed..
| MrKona |
Feb 21 2009, 12:28 AM
My homemade tool in action!
| MrKona |
Feb 21 2009, 12:30 AM
And the result! Held the big bolt with a Vice Grip, turned the nut, and the bearing came out like buttah!
| MrKona |
Feb 21 2009, 12:31 AM
Bearing removed...
| MrKona |
Feb 21 2009, 12:36 AM
Question... the inside of the trailing arm looks as though it has a plastic sleeve in there... am I seeing this correctly? The reason I ask is that I was planning on bringing both trailing arms to the local metal cleaner and have the grease and grime taken care of before I have them powdercoated. However, if these are dipped, the plastic will melt. Anyone know for sure? There's just too much grease in there still for me to get a good look.
I also need to call my local powdercoater and ask him how dirty a piece he'll accept. I know media blasting can clean parts up, but these are really dirty... Attached image(s)
| Gint |
Feb 21 2009, 08:53 AM
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,111 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Question... the inside of the trailing arm looks as though it has a plastic sleeve in there... am I seeing this correctly? The reason I ask is that I was planning on bringing both trailing arms to the local metal cleaner and have the grease and grime taken care of before I have them powdercoated. However, if these are dipped, the plastic will melt. Anyone know for sure? There's just too much grease in there still for me to get a good look. I also need to call my local powdercoater and ask him how dirty a piece he'll accept. I know media blasting can clean parts up, but these are really dirty... There is no plastic in there. Just grease... and dirt. |
| kconway |
Feb 21 2009, 09:07 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,347 Joined: 6-December 04 From: Monrovia, CA Member No.: 3,231 Region Association: Southern California |
Did all of the bearing come out? Isn't there suppose to be a cover over the balls?
Lo-Fi Version | Time is now: 22nd October 2026 - 09:15 PM |
