Anyone add an ac compressor to a v8 914?, Fabricators please chime in... |
computers4kids |
Feb 15 2009, 11:15 AM
Love these little cars! Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None |
I'm toying with how to add an AC compressor to my SBC 914. Specifically I'm looking for ways to mount the compressor and where. I've seen some pics of what appears to be a sanden universal compressor mounted down low on the passenger side by the engine bar. Renegade wants almost $700 dollars for the brackets that holds the alternator and ac compressor, which is ridiculous (replaces the smaller bracket seen below that holds the alternator).
Anyway, I would like to fabricate my own and would love to see any other examples of a mounted compressor in a V8 914 to give me vision how it might work. Seriously, it can't be that hard. Here's some pics to get you an idea what I'm working with. The top view of the engine compartment is actually my 914...the others are identical in setup but not my engine. Thanks! |
Sleepin |
Feb 15 2009, 12:29 PM
Advanced Member Group: Members Posts: 3,647 Joined: 20-November 07 From: Grand Junction, Co. Member No.: 8,357 Region Association: Rocky Mountains |
Doing some recent reading I found this for you:
(IMG:http://www.914world.com/bbs2/uploads/post-287-1153119889.jpg) (IMG:http://www.914world.com/bbs2/uploads/post-287-1153119908.jpg) (IMG:http://www.914world.com/bbs2/uploads/post-287-1153122076.jpg) Thread here: http://www.914world.com/bbs2/index.php?sho...impson&st=0 |
LvSteveH |
Feb 15 2009, 01:26 PM
I put the Poor in Porsche Group: Members Posts: 1,080 Joined: 22-April 03 From: Las Vegas, Nevada Member No.: 600 |
Renegade wants almost $700 dollars for the brackets that holds the alternator and ac compressor, which is ridiculous (replaces the smaller bracket seen below that holds the alternator). As you can see from Sleepin's pics, it's not just a bracket replacement, it converts the engine to a serpentine configuration, which requires changing the harmonic balancer and waterpump pulley. Granted it's not cheap, but it's far from ridiculous. It's tricky to get three accessories driven in the amount of space available, and the serpentine upgrade has provisions for four. There's also a spot for an optional emissions pump if needed, just below the a/c in the pics. I suppose you could change the waterpump to electric and run the a/c compressor there, but in the end you'd be hard pressed to save money. |
marks914 |
Feb 15 2009, 01:51 PM
Senior Member Group: Members Posts: 845 Joined: 9-October 04 From: the motor city Member No.: 2,912 Region Association: None |
I was thinking of going with the desert hybrids setup on mine. I already have the rest of their stuff. You can use it on a renegade setup too, just flip the brackets around for the other side
Mark (IMG:http://inlinethumb43.webshots.com/40362/1065449456044799202S600x600Q85.jpg) (IMG:http://inlinethumb09.webshots.com/39368/1065449505044799202S600x600Q85.jpg) |
computers4kids |
Feb 15 2009, 05:25 PM
Doing some recent reading I found this for you: Thread here: http://www.914world.com/bbs2/index.php?sho...impson&st=0 Thank you for the pics...the Renegade setup. Looks like quite a change, other than just a bracket. |
computers4kids |
Feb 15 2009, 05:30 PM
Renegade wants almost $700 dollars for the brackets that holds the alternator and ac compressor, which is ridiculous (replaces the smaller bracket seen below that holds the alternator). As you can see from Sleepin's pics, it's not just a bracket replacement, it converts the engine to a serpentine configuration, which requires changing the harmonic balancer and waterpump pulley. Granted it's not cheap, but it's far from ridiculous. Probably makes more economical sense if you don't already have the original Renegade setup. Very nice setup...makes a little more sense the price tag. I thought about going with a Meziere electric water pump and using the bracket for the mechanical pump but your right...it just doesn't make sense dollar wise. |
computers4kids |
Feb 15 2009, 05:36 PM
I was thinking of going with the desert hybrids setup on mine. I already have the rest of their stuff. You can use it on a renegade setup too, just flip the brackets around for the other side Mark (IMG:http://inlinethumb43.webshots.com/40362/1065449456044799202S600x600Q85.jpg) (IMG:http://inlinethumb09.webshots.com/39368/1065449505044799202S600x600Q85.jpg) I'll have to check into this...promising. So the AC is driven off the balancer and the alternator is driven off the AC all with standard v belts. I have a mint dpd evaporator that is literally new which I've already installed. I just need to figure out the compressor mounting and the rest will be easy. (IMG:http://www.914world.com/bbs2/uploads/post-4253-1234156843.jpg) Thanks for the tip...time to check out their system. |
Bruce Hinds |
Feb 15 2009, 11:59 PM
V-8 madness Group: Members Posts: 733 Joined: 27-December 06 From: Port Orchard, WA Member No.: 7,391 Region Association: Pacific Northwest |
I don't have a picture handy, but marks914 is similar to mine. Renegade with water pump on passenger side is the same, but my alternator is on top of the compressor for a few reasons.
Shorter run on compresser hoses. Alternator is right next to electrical box and the alternator is run of the aft pully slot on the compressor to move the alternator farther aft for firewall clearence. I also run the full tube early corvette headers and there's room for everything. Not sure if I have a picture, the compressors out of the car right now..... B |
computers4kids |
Feb 16 2009, 09:13 AM
I don't have a picture handy, but marks914 is similar to mine. Renegade with water pump on passenger side is the same, but my alternator is on top of the compressor for a few reasons. Shorter run on compresser hoses. Alternator is right next to electrical box and the alternator is run of the aft pully slot on the compressor to move the alternator farther aft for firewall clearence. I also run the full tube early corvette headers and there's room for everything. Not sure if I have a picture, the compressors out of the car right now..... B Very cool (IMG:style_emoticons/default/laugh.gif) & encouraging news. If there is anyway a picture surfaces in your world I would love to take a gander. Your description really helps, but I'm very visual. If I see something I usually can fabricate it or make it work. Do you remember what kind of compressor you used and where you sourced the brackets (desert hybrids)? I emailed them yesterday...I couldn't find any info on their site other than pictures like what marks914 provided. Since my car is already wired (alt passenger) and water hoses plumbed to the pump on the driver's side, I would like to make the compressor work on the passenger's side. Another Thought: If I were to add a compressor above the water pump on the stock Renegade setup (driver's side) is that not a good idea because both of these accessories (when running) are such large draws on the system. Is it better to have more balance (alt & compressor.....waterpump driven off diff. belts)? Thanks again for the ideas...the wheels starting to turn (IMG:style_emoticons/default/idea.gif) |
Lo-Fi Version | Time is now: 15th May 2024 - 11:12 PM |
