need more help... air cleaner this time, picture would be wonderful |
brant |
Feb 22 2004, 01:22 AM
Ok,
new problem. I've got a 74-2.0/4 with injection. I bought it from a kid who did not know what he was doing when he pulled it (from ginters old car)... kid, took the throttle body off and all kinds of weird things just to drop the motor. I of course bought it in this state with misc. boxes full of throttle body, AAR, etc. Problem: So I'm trying to put the air cleaner box back on and re-attatch the vacuum lines. I just noticed that there needs to be some type of mounting bracket under the air cleaner (attatched to the manifolds?) that the air cleaner obviously should clip to. I don't have this silly bracket included in the misc parts. Does anyone happen to have this bracket left over from a carb conversion.... Also, I don't even know what it should look like.... Does anyone have a picture of this bracket. I might be able to fab up something so that I can be done with this tomorrow, but a picture would really really help.. (ginter do you know the kids contact info... I lost it.. I'll PM you.) thanks again guys.. don't know what I'd do without you all. gotta love this board... p.s. now I remember why I never had FI cars for the last 15years. ha... brant |
RocknRollFrenzy |
Feb 22 2004, 03:41 AM
Member Group: Members Posts: 94 Joined: 3-November 03 From: Santa Cruz, CA Member No.: 1,305 |
i've still got one on my car, and it just happens that i've got my air box off at the moment. i'll try and get a picture up for you after breakfast tomorrow if someone else hasn't done it by then.
brant |
Feb 22 2004, 09:27 AM
boy that would be great... if you don't mind...
then I'll take a shot at fabricating one. tia brant |
Feb 22 2004, 10:37 AM
914 Idiot Group: Members Posts: 14,984 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
The bracket consists of two bent pieces of sheetmetal. One is relatively short and has an upward vee in the middle, kind of like: -^- . There is a hole in the middle of the vee. A ~2" long bolt goes through that hole, and then a metal spacer collar goes over the bolt. The upper part has a recess with a hole in it for the nut that goes on that bolt. It is pretty much flat, except for a bit of a bead around the edges for stiffening. It has little rubber "feet" facing upward so that the airbox does not chafe.
The top piece of metal is about 2" wide and 10" long--long enough for the clips on the bottom of the air cleaner to grab it. The lower one is only about 4" long, and is narrow enough that it can slip between the intake pipes sideways. I think the bolt is actually a carriage bolt with a square section under the head (like the alternator pivot bolt is) and the hole in the lower piece is square. This keeps the bolt from turning when you tighten the nut. You slit some old "manifold boots" (AKA the large vacuum hoses) and slide them on the intake runner pipes to pad the bracket. Then you slide the lower piece, with the bolt in it, in between the runners. Slide the upper part onto the bolt, tighten. Then you can clip the air cleaner onto the top part. --DD |
TheCabinetmaker |
Feb 22 2004, 10:40 AM
Four pics coming up.
Attached thumbnail(s) |
TheCabinetmaker |
Feb 22 2004, 10:41 AM
#2
TheCabinetmaker |
Feb 22 2004, 10:42 AM
#3
TheCabinetmaker |
Feb 22 2004, 10:43 AM
#4. Sorry for the big pics. I resized them the same as always, but it didn't seem to work this time
TheCabinetmaker |
Feb 22 2004, 10:45 AM
Sorry, ya can't have mine, but I would try to find an original if I were you
Good luck and let us know how it goes. |
415PB |
Feb 22 2004, 10:56 AM
Member Group: Benefactors Posts: 498 Joined: 7-August 03 From: So Cal Member No.: 996 |
Brant, I think I have an extra one, let me know if you found one.
Rod |
brant |
Feb 22 2004, 01:31 PM
wow...
I've got to thank everyone.. The pictures helped a ton. I made one out of metal.. sort of copying from the original and the pictures really helped. thanks for the time... the offers... the description, and help everyone.. have a good day brant |
mike_the_man |
Feb 23 2004, 11:24 AM
I like stuff! Group: Members Posts: 1,338 Joined: 11-June 03 From: Regina, Saskatchewan, Canada Member No.: 809 |
Rod,
I need one of these brackets also. Still got one that you want to sell? |
415PB |
Feb 23 2004, 01:41 PM
Mike, I found it. Your more than welcome to it if you need it.
Rod |
mike_the_man |
Feb 23 2004, 02:14 PM
Rod,
You have a PM! |
415PB |
Feb 23 2004, 05:22 PM
Mike, you have a PM back
Lo-Fi Version | Time is now: 12th May 2024 - 04:20 PM |
